what rear end do i have?? 92 rs
Old Sep 24, 2004 | 08:43 PM
chevboy28's Avatar
Car: 1992 25th anniversary camaro
Engine: 406
Transmission: t56
Axle/Gears: 410s
it's a 92 rs 25th with the 305 tbi and i need a posi but i don't what kind of rear end is in it?
Old Sep 24, 2004 | 08:54 PM
del91_305's Avatar
Car: 1991 camaro RS
Engine: 305 Carb
2.73 Limited slip
Old Sep 24, 2004 | 08:58 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
I'm pretty sure that it's a 10-bolt 2.73 open rear. That's what most of the RS's came with stock. The two definite ways to check are to check your RPO codes (should be code GU2) and/or jack the car up and physically look at the rear you have.
Old Sep 24, 2004 | 10:11 PM
25THRSS's Avatar
Old Sep 24, 2004 | 11:40 PM
parks911's Avatar
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
OK, where do I find these RPO codes?
I've been looking everywhere & can't find them.
I even looked for a build tag like Ford has in the door jamb.
Old Sep 24, 2004 | 11:45 PM
25THRSS's Avatar
I believe on your car they will be inside the locked storage door in the rear hatch. You can always go to the dealer and give them your VIN and they can print out an RPO sheet for you as well for free.
Old Oct 1, 2004 | 10:14 PM
parks911's Avatar
Car: 91 Camaro RS
OK, found the RPO codes & have the GU2 tag.
Now, how can I get this thing turning posi? Do I have to swap out the whole rearend or will swapping the third member do it? :shrug: :shrug: :shrug:
Old Oct 1, 2004 | 11:35 PM
25THRSS's Avatar
just replace the differential with something like an eaton.
Old Oct 2, 2004 | 03:18 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
if its the stock 92 rear end (28 spline axles), talk to slp. $99 and youll have posi
Old Oct 2, 2004 | 05:02 PM
25THRSS's Avatar
SLP ran out of stock a long time ago. No more $99 posi. The eaton unit is better anyways.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
