t5 input shaft bearing replacement???
Old Jul 2, 2004 | 08:10 AM
chevytruck68's Avatar
Car: 86 camaro
Engine: 2.8
Transmission: 5 speed
ok i have a 86 camaro with 2.8 and 5 speed. i am replacing the motor,and i noticed after i pulled the old one out that my transmission input shaft has a lot of play in it and i thought that replacing the bearing would help. but i need to know how much work this will be. if i need to tear the whole tranny apart ill just put it back together and start looking for a new tranny. any help would be appreciated. a new bearing and seal is only like 15 bucks so if it is easy ill fix it now.
Old Jul 2, 2004 | 08:49 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
i dont remember correctly but i think you remove that front retainer and turn the input shaft till the flat end lines up with the cluster gear, anyhow you have to remove the top cover and the tailhousing, might as well rebuild the whole thing while your there or get another
Old Jul 2, 2004 | 08:53 AM
Car: 86 camaro
Engine: 2.8
dang and i was hoping you just pulled the retainer and the bearing would come out and i could throw in a new one with seal and call it a day. thanks anyway
Old Jul 3, 2004 | 05:20 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Some play is normal. The tip of it will be supported by the pilot bushing/bearing.
Old Jul 5, 2004 | 04:25 PM
Car: 86 camaro
Engine: 2.8
i know some play is normal but im seeing somewhere between 1- 1 1/2 inches total up and down
Old Jul 5, 2004 | 09:13 PM
CHEVY_EATER's Avatar
Car: 93 Mustang GT
Engine: 5.0
Well....it COULD be easy or not! You could just take it apart and replace the bearing but make sure you are careful and look up the specs for play and preload. I freshened my T-5 in my Mustang myself and it was not too bad but I had a repair manual and a video. I took my time and put a complete rebuild kit in it sicne I needed to replace the countershaft gear set and my 3rd gear...blew apart somehow!!!
Old Jul 6, 2004 | 08:04 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
I bet with that much play that the roller bearings in the cup part of the input shaft and the tip of the main shaft are history!
I'm sorry to say but I bet total rebuild time...
Old Oct 2, 2004 | 03:50 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
So, how much play is normal? I just scored a wc t5 at the bone yard and noticed some side to side/ up down play on the input shaft. Nowhere near 1- 1 1/2 inches.... but visible to the eye at least.
Old Oct 2, 2004 | 05:36 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
when its new and tight there shouldnt be any play...infact a slight and i do mean slight drag is required to set the bearings...and after there set very little play like 2 tenths or less....anymore then that and the clutch gear beairng aswell as the mainshaft bearing are gone....probly the 15 rollers bearings to...
ohh and as far as removing the clutch gear...you can do it without taking off the cover lid or the tailhousing..put the tranny in 3rd gear and slide it out with the posted directions....it would also be smart to tilt the rear of the tranny towards the ground a little...this will keep the torrington bearing, race and spacer from falling into the bottom of the case....thus resulting it tear down anyway
red90IROCls1
Aug 25, 2015 06:56 AM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
marcusaw
Aug 10, 2015 08:13 AM
MENINBLK
Aug 5, 2015 11:58 PM
