Tranny Question, Help
Old Sep 26, 2004 | 08:53 PM
bbigbrn612's Avatar
Car: 1984 z28
ok so i need to know what is compossed of a manual tranny. my problem is that i want a manual not an auto, would all i have to do is get the linkage from the same year car for a manual? and what all would i have to get?
Old Sep 26, 2004 | 09:04 PM
bbigbrn612's Avatar
Car: 1984 z28
also, i have this book, classic industries catalog. would that book have everything i needed for the switch? or am i going to have to look for the linkage in a junk yard?
Old Sep 26, 2004 | 09:18 PM
parks911's Avatar
Car: 91 Camaro RS
Engine: 350 Police with some MINOR modifica
Transmission: kitted 700R4 & vette servo
The link I posted below will tell you everything you need for your swap. It will also tell you how to do it.
As for your book, I'm not sure if all the parts you will need are in there. I would look in salvage yards first.
https://www.thirdgen.org/newdesign/t...nualswap.shtml
Old Sep 26, 2004 | 09:28 PM
bbigbrn612's Avatar
Car: 1984 z28
thank you very much
Old Sep 26, 2004 | 09:47 PM
bbigbrn612's Avatar
Car: 1984 z28
thats helpful, but actually i want to put in a 355 with the stock 5 speed tranny work with that? or will i need a new tranny? theres a richmond 5 speed i was looking at, but would i fallow those same instructions?
Old Sep 27, 2004 | 12:42 AM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
From my understanding, a regular 3rd Gen. F-Body 5 speed will not last long behind 350. This is why you do not see a stock 3rd Gen. F-Body that has a 350 mated to a 5 speed. The torque produced by the engine would kill the tranny. I know of a few that have had 5 speed behind a 350 but they are built to handle the HP/torque. Depending on what your 355 will produce, your stock 5 speed will last for a while until you get a replacement or even better, why install a 6 speed.
Old Sep 27, 2004 | 04:25 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
if you have any real power don't put in a t-5 I've gone through 2 and my 3rd is on it's way out, go with a t-56
Old Sep 27, 2004 | 04:50 AM
screaminformula's Avatar
Car: 1987 F150...PAAARTY FOUL!
Engine: 300 I6 stump pullin sumbiscuit
Transmission: 4 speed grind box
Axle/Gears: 3.55 unlimited slip differential
yea, i agree with the look in the salvage yards first thing...just buy your soft parts (hoses, slave cylinder) new...the rest of the stuff will be fine used. also, don't trust a T-5 stock behind anything with serious power...my friend killed his in a matter of a year behind a TPI 305, and i have killed 2 behind TPI 305's...
Josh
Old Sep 27, 2004 | 11:56 AM
bbigbrn612's Avatar
Car: 1984 z28
ok, now my main question is will i have to modify the frame, or the brakets to put in the t-56? its auto now, im going to convert to the t-5 then go to the t-56 will what i do to make the t-5 also help to make the t-56 fix snug or am i going to end up spending more money than i need to.
Old Sep 27, 2004 | 01:28 PM
Engine: 383
t-5 will bolt in place of the auto, no problem, just cut the hole in the floor and cut the holes for the master cylender (the holes ore scored on the pad under the carpet, just trace to the meatle and cut, the hardest part is getting the brake booster/master cylender out), for the t-56 you will need to modify you crossmember or buy an aftermarket one, they go for $150-200 also the clutch/flywheel is diffrent and if U have a 1 peice rear main engine the factory T-56 combo will bolt on, but if you have a 2-pice it won't fit and you will have to do some reshearsh and decide which way is the best for you, also the speedo is eletric, which means you need to convert the car to an eletric speedo or have the tranny tailshaft machined to accecpt the mechanical speedo's "bullit"
Old Oct 2, 2004 | 04:46 PM
parks911's Avatar
Car: 91 Camaro RS
I'm glad I was able to read this before I made a decision.
I have actually been thinking about swapping my lame 700R4 for T-5 (gotta love those stick shifts). :yes:
Now I will look at the T-56. :rockon:
84 Z-28 350, :hail::hail::hail:
I'm assuming you are speaking about the mechanical speedo that bbigbrn612 has in his 84. I beleive that my 91 RS has a electric speedo already. :shrug::shrug::shrug:
Thornburg
Aug 25, 2015 01:46 AM
spaigo
Aug 21, 2015 07:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
