4th Gen Posi Carrier..
Old Oct 2, 2004 | 05:50 PM
prOject-IrOc's Avatar
Car: 1990 Iroc-Z
(quick quesiton) 4th Gen Posi Carrier..
...should swap right in to my 90 Iroc rear end...right?
28 spline..
Old Oct 2, 2004 | 06:53 PM
ljnowell's Avatar
Depends on what gears you have, I believe.
Old Oct 2, 2004 | 07:01 PM
Car: 1990 Iroc-Z
i will be puttin 3.73's in the carrier. my car has 3.42 posi now.
Old Oct 2, 2004 | 07:36 PM
ljnowell's Avatar
Well, as long as the posi unit is a 3-series carrier, it will work just fine.
Old Oct 3, 2004 | 08:51 AM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
Just make sure that IROC doesnt have a 9 bolt. Its a totally diffrent animal then the 10 bolt. If your car is factory with the L98, then I am 99.9% sure you have a 9 bolt.
Old Oct 4, 2004 | 04:48 AM
MdFormula350's Avatar
9 bolts were during the 86 - 89 thirdgens, 90 - 92 were 10 bolts with 28 spline axles.
https://www.thirdgen.org/newdesign/tech/techdb.shtml
Old Oct 4, 2004 | 07:36 AM
Car: 1990 Iroc-Z
thank you very much. so the 4th gen posi unit should bolt right in...correct?
Old Oct 4, 2004 | 05:32 PM
Car: 1990 Iroc-Z
bump. i need to know for certain.
Old Oct 4, 2004 | 07:34 PM
ljnowell's Avatar
If you have a 10 bolt with 28 spline axles, and you have the right series carrier to match the posi unit, then yes it will be a direct bolt in.
Old Oct 5, 2004 | 09:49 PM
Car: 1990 Iroc-Z
i bought it.
:lala:
http://cgi.ebay.com/ebaymotors/ws/eB...tem=7925600846
Old Oct 8, 2004 | 10:50 PM
91TPI5.7's Avatar
Car: 1991 z28
Engine: l98
On the contrary, the IROCS, except for the most base model version, have a BW 9 bolt. Easiest way to find out is to look.
Orr89RocZ
Apr 25, 2016 08:28 AM
Orr89RocZ
Oct 7, 2015 12:47 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
