Transmission is fired!!!! oh no
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Transmission: 700-R4
Today i started up the car for the long journey to school, drove it to the stop sign and noticed it didn't shift, thought i was just missing something or whatever. well it wont shift out of first now.
what could be the problem guys.
the fluid is still red after 38k miles of being used so thats still a good sign.
the guy at a local shop said there is a nylon gear that is spun, and its very common for them to wear out and it wont shift becuase the car doesn't know how fast the engine is spinning. IS this true?
shane
shane
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
I second that. Pull the governor cover off and pull out the governor. Has a little plastic gear on the end of it. Probably wore out and all the teeth stripped off. Without it turning, there is no indicator of the vehicles speed.
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Sounds like the Ghost of Many Threads past has come back to haunt you. Remember the ones where you were bragging and complaining about your transmission and other members warned you that it was on its last legs and you blew them off.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
nah it was the governor, i replaced it myself yesterday morining at like 9AM, when it was like 50* outside.
I pulled it went to Mark Twain Transmisions and he sold me the gear and valve for $20, put it in and was on my way to work.
Thanks for the help guys.
sorry trickster, i do have a shift kit. its been proven now.
Shane
Shane
Car: 88 Camaro SC
Engine: SFI'd 350
It was probably all that shock loading from peeling out and stuff that encuraged it to break. On mine at the base of the gear there are numerous fatigue fractures so it was only a matter of time before it broke off.
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
Originally posted by ljnowell
Yeah, cause transmissions grow them all the time!
LMAO...maybe he was using that trick shift tranny fluid..LMAO
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Shane
Shane
Car: 1986 Trans Am
Engine: 305 LB9 TPI
or maybe the damn oprevious owner put one in you dumb ****s. gosh leave me alone about it. it is an aftermarket shift kit. i dont know actly what brand, but my step-dad said he noticed it wasn't stock when he put in the tranny fluid screw(an addon to let you dump tranny fluid before unbolting the tranny pan).
Car: 86 Camaro
Engine: none
Transmission: none
Axle/Gears: GT4, 3:73s
somebody forgot to take their midol
Car: 88 Camaro SC
Engine: SFI'd 350
Its a possibility, but I always assume a problem before believing that my car is somehow special and different from the other 10 zillion ones just like it on the road.
P.S. you really cant 'see' a shiftkit. The valvebody itself is in the way. Youd have to drop it and inspect to see whats been changed.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
sorry but you guys continually treat me like i'm just stupid and dont know the difference betweena good shift and a broken one.
i'm not stupid anymore guys, i'm actually learning and tkaing advice now. I did my reasearch on the site after i posted and found out it was the gear, took it out and walla.
Teh definition of education is being able to teach yourself what you need to know to get stuff done, therefore look it up.. YOu guys have helped educate me. thanks
and sorry trickster, you've helped me throguth out the time, more professionally then anyone else, i should not have exloded on you.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
Originally posted by dimented24x7
Yeah, thats definatly a no-no. Personal attacks and name calling are not allowed. Dont do that again.
and if that were true, wouldn't that make sence thata new valve body comes with the dang thing. My step-dad is no looser. He was a district manager of a set of mechanic shop in the saco ,maine area back in the day. Hes no dummy either.
Car: 88 Camaro SC
Engine: SFI'd 350
Thats fine. You can defend yourself, but just leave out any harsh words and make sure to do it in a respectful way.
Before going any farther, Id double check that the tv cable has FULL tension at WOT. It needs to be tight. A stuck tv valve will also cause super hard shifts. If the trans still shifts normally at low loads and the cable is nice and tight at WOT then its ok. If it shifts hard all the time then suspect a stuck tv valve. Mine did it all the time. Currently rebuilding it with a HD trans-go shiftkit so hopefully those problems should be a thing of the past.
Car: 88 Camaro SC
Engine: SFI'd 350
Car: 1986 Trans Am
Engine: 305 LB9 TPI
mine shifts firm, not hard, no slippage or anything, i had it checked out. the tranny guys said its the resemblance of a shift kit from long time past. they didn't know for sure but thought it was very possible.
Car: 88 Camaro SC
Engine: SFI'd 350
mine shifts hard all the time d00d, liek tis supposed to.
Car: 88 Camaro SC
Engine: SFI'd 350
All that shock loading is hard on the parts inside. Fast, firm shifts are fine for WOT but not all the time. Itll break stuff. Try pulling the TV cable all the way ouy a bunch of times. That seems to be able to free the valve up. If its still stuck, then thats a perfect excuse to drop the pan and put in a real shift kit that will take the slush out of your box.
Car: 88 Camaro SC
Engine: SFI'd 350
Originally posted by nsimmons
yeah you are...
yeah you are...
Use the PM feature. I personally couldnt care less what you do so long as its not on the boards. Last edited by dimented24x7; Oct 18, 2004 at 11:06 AM.
Car: 1986 Trans Am
Engine: 305 LB9 TPI
so ok, let me get this straight, just pull pull on that cable with all my might for like 10 times and it should come loose?
Shane
Shane
just like this.....
Go out and disconnect the tv cable and pull it all the way out and let it go fast as you can a bunch of times.
Car: 88 Camaro SC
Engine: SFI'd 350
Yes, In theory it should come loose. It seemed to work every time for me when the TV valve got stuck. Of course it was all the garbage in my ATF from a slipping 2-4 band that caused it. Filled the trans up with crap.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
