What can I change my t-56 stock trans to??
Old Oct 25, 2004 | 03:45 PM
GTA350VORTEC's Avatar
Car: Black on Black 1989 GTA
Engine: 5.7L Vortec TPi
Transmission: 6 Speed T56
Axle/Gears: 3:73
I have an 1989 GTA 5spd......recently I started to notice whinning noise from the 1st and 2nd gear and also in reverse. Since I'm pretty sure those sounds arent good, I know I'm going to be looking at buying a new transmission soon. Does anyone know of a good unit I can purchase that will be a lil beefier and durable than the stock one? Also can it just bolt right in or am I gonna have to fabricate alot? All help greatly appreciated.
Old Oct 25, 2004 | 03:57 PM
Spectre's Avatar
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
Re: What can I change my t-56 stock trans to??
stock, you have a 5 spd, get a 6 spd.
you kinda answered it yourself lol
Old Oct 25, 2004 | 04:00 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Or have Tremec rebuild it for approx $700 from what I've read on here and be good to 450 or so HP....
That way you bypass all the conversion stuff.
Or get a "built" 700R4 if you're tired of shifting it yourself. They bolt right up and use the same drive shaft.
Old Oct 25, 2004 | 04:32 PM
Axle/Gears: 3:73
No I want to keep the car manual.....its a rare combo GTA 5.7TPi T-Tops and 5spd. So tremec will do a rebuild for $700? Do I have to send them a core and they send me a new one or is the actual work done to my original trans itself?
Old Oct 25, 2004 | 06:49 PM
Spectre's Avatar
Engine: 3.0L/183
Is all that written in the RPO codes ?
If you get a trans rebuild, you sent the a core, if not, you'd be buying a rebuilt trans.
If you do a lot of highway driving.. or do autocross .. look into
the T5-6 as a second option.
THo if you get you're rebuilt for 700$ .. from tremec, I doubt its worth getting a 6 spd, unless you need the 6th gear.
Old Oct 25, 2004 | 07:39 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
From the factory a 350 would have had a automatic and as far as rare goes, I've seen a few 3rd gens that had replace their 700R4 for a 5 speed . You may want to look at you RPO codes as spectre replied to your post. As to getting a 6 speed, it would be easier/cheaper to rebuild the 5 speed to handle higher torq then to convert to a 6speed.
Old Oct 25, 2004 | 09:01 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
or he may have a 5.0 + 5spd.
Old Oct 26, 2004 | 01:42 AM
Axle/Gears: 3:73
When I first ran the RPO codes thats exactly what came up. I'll definately stick with the original 5spd that requires less modification, anyone got a good place to purchase one of these?
PS I think I run those RPO's again just to double check
Old Oct 26, 2004 | 08:26 AM
vernw's Avatar
Yeah, you'd better. No way the RPO's come up with 5.7 and T-5.... ypu've probably got the "F" engine (305 HO, possibly with dual cats)
Old Oct 28, 2004 | 02:17 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
here we go again.
Old Oct 28, 2004 | 12:49 PM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
tell us the Vin number that will tell if u have the 5.7 or 5.0
Old Oct 28, 2004 | 02:12 PM
IEatRice4dinner's Avatar
Car: IROC-Z
Engine: L98 350/ 5.7L
no 5.7L came with 5 speeds. eather it's a 350 with a t-5 swapped in or a 5.0L with 5 speed and a 350 swaped in if it is even a 350
Old Oct 28, 2004 | 09:23 PM
FndmntlsOfPimpn's Avatar
Car: 87 Formula
Engine: 350 tpi
Axle/Gears: Stock 9 bolt
the whining sounds tends to happen on highmiealige trans or if has been run low on fluid at one time mine did it not really a problem but a rebuild is a good idea id reccommend checkin ur tranny fluid first asap
Old Oct 28, 2004 | 10:49 PM
Axle/Gears: 3:73
Whats the fluid capacity of our TransMissions?
Old Oct 29, 2004 | 10:13 AM
Car: 87 Formula
Engine: 350 tpi
6.5 pints
Old Oct 29, 2004 | 11:10 AM
ljnowell's Avatar
here we go again.
Old Oct 29, 2004 | 12:26 PM
pasky's Avatar
Originally posted by FndmntlsOfPimpn
6.5 pints
3.8 quarts I believe.
Not to say your 6.5 pints is wrong, I only know the quarts measurement.
Old Oct 29, 2004 | 02:16 PM
Car: 87 Formula
Engine: 350 tpi
almost the exact same thing i jus rember thats what my owners manual said
Old Nov 1, 2004 | 04:51 PM
DeWynter's Avatar
Only test cars were built with 5-speed and t-tops, no productions. To belive that this car is real I would have to see a pic of the rpo codes and the vin.
Old Nov 1, 2004 | 05:07 PM
Car: 87 Formula
Engine: 350 tpi
Say what?? i have an 89 rs 5 speed with t tops and my rpos show both
maroe624
Apr 16, 2017 08:29 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
gta power
Aug 13, 2015 06:15 AM
Exxon Limited
Aug 9, 2015 08:13 PM
cRoe4
Aug 7, 2015 08:46 PM
