still confused- 3.73 or 4.10/4.11?
Car: 88 S-Dime
Engine: 388
i have searched for my combo and gear selection- but i am still unclear as to what to get. some people say the 3.73 are stronger others think different. i am also confused as to what tc to get- which will work best with my gears/cam. this s-10 will be used for occasional weekend fun as well as drag racing. here is what i have:
383 with the cc306 cam (1.6 rockers)
between 10:1 and 11:1
heavily worked 113 heads
converted lt1 intake
700r4
7.5" rear
powertrax no slip
moser 28 spline axles
welded tubes
studded girdle
solid pinion spacer
26" or 26.5" (can't remember) hoosier QTP's
which gears should i buy and what stall on the tc? i was thinking about a 2800-3000 stall but on the fence with the gears. i am thinking of richmond or motive brand gears. i dont really care about gas mileage but i dont want to put the 3.73 in and wish i had put the others in later. don't know if it matters- but as i mentioned above this will be in an older body style s-10, and those are relatively light
700r4
7.5" rear
powertrax no slip
welded tubes
studded girdle
solid pinion spacer
Car: 88 S-Dime
Engine: 388
i did however the engine, tranny, and computer came from a 3rd gen. do i get any points for the fact that the 3rd gens are still my fav. style of f-body? :hail:
Car: 86 IROC-Z (daily driver) 87 IROC-Z (under construction)
Engine: 305 H.O.
I'll give ya 10 points. thats always a good excuse in my book. It sounds like your headed in the right direction. im not gonna pretend to act like i know what im talking about when it comes to your question so i leave this to the pros. I just hope you get some answers before this gets
good luck!
good luck! Member
Engine: 305 H.O.
Originally posted by ljnowell
Big stall, big cam, go with the 4.10's. Here comes the lock
Car: 88 S-Dime
Engine: 388
dare i ask why this would get locked? i am asking a legit question- about these cars more or less. i have posted several other questions on here before w/o getting locked- i dont see why this one would be any different- besides the fact that this time i said what the gears were going in.
anyway- thanks for the advice- i was kinda thinking the 4.10/4.11 but i am still kinda scared of them breaking- not that the 3.73 would make the 10 bolt bullet proof
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
[QUOTE]Originally posted by TPIs-10
[B]dare i ask why this would get locked? i am asking a legit question-
Ummm...because this is a Thirdgen site and not an s-10 site?
I would go with the 3.73's. Going with 4.10s will not make your rear end blow up as opposed to the 3.73's. With the .7 overdrive and the fact that you are still running factory heads, you will be better off with 3.73's. If you had a T-56, then I would go 4.10s.
HTH,
HTH,
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Seeing as you have quite the motor there you might only need 3.73 with all that torque, but 4.10 wouldn't hurt you at all.
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
With that short of a tire, the fact these S-10's dont weigh hardly anything you should be using the 3.73's. It'd be different if your truck weighed 34-3600lbs but your probably a little lighter than that, so the way the motor sounds and the minimum weight you have it'll be all done before the finish line.
If your want to run the 4.11's get a minimum of a 28" tall tire.
Either way, your still going to have traction issues. Fought this in our tubbed S-10 running 31x14.5" slicks with 4.30 gears and a glide.
Car: 88 S-Dime
Engine: 388
thats another thing i was worried about- traction with the 4.10's- not that the others will hook a lot better- but slightly better i would assume. although- i want this rear to last a little while- since i am about out of money- so i will have to save for a 12bolt or 9". i am hoping with the cheater slicks it will hook fairly descent (after getting them warm)- i would like a little wheel spin rather than nothing at all- less likely to break something. i was talking to the guy that did me heads last night- he said he thought i should go with the 3.73 because of how short the tires are. looks like it's time to head the the local shop and get some gears so i can get this thing buttoned up and hopefully drive a littl before it's time to put it away for the winter.
thanks for the advice.
i was thinking that i wasn't the only one roaming around on here w/o a third gen.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
