Installed my LS-1 Alum. driveshaft ....
Old Oct 31, 2004 | 01:28 PM
Brock's91RS's Avatar
Car: 87 IROC
Engine: mini-rammed 350
Transmission: WC T-5
All i have to say is ...it was money WELL spent
Dunno how much actual power you gain..In my case that would be an extra...because it did away with my high speed(80+) vibration!
Later
Steve
Old Oct 31, 2004 | 05:54 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Yeah, they are a wise investment.
Old Oct 31, 2004 | 06:07 PM
ScottyRS's Avatar
Car: 1992 Camaro RS
Axle/Gears: Stock
I've been looking into getting one of those. How much did you get yours for?
Old Oct 31, 2004 | 06:12 PM
Mr.Crackhead's Avatar
Car: 1990 Formula
Engine: 355
is there any changes needed to make this work or is it a direct fit in a T5 car. I happen to have a LS1 T56 shaft sitting here.
Old Oct 31, 2004 | 06:19 PM
Car: 87 IROC
I got VERY lucky,I paid JUST $75 for mine,off e-bay,I believe the guy messed up with his "BUY IT NOW"
It is a direct bolt-in..no mods whatsoever
Good luck
Steve
Old Oct 31, 2004 | 07:17 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Obviously its got an advantage over a stock iron thirdgen DS.
But how much is it than the 3rdgen Aluminum DS? I know its thicker, i think 3.5" to our 3", how much more does it weight? The reason I'm asking is because my Aluminum DS in the GTA is pretty beat up where the rear U-joint bolts up. I can still get one in there, but for peice of mind I'm considering a swap.
Old Oct 31, 2004 | 10:09 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
Thirdgen aluminum was 2.5"
The LS1 aluminun is 3"
THe LS1 aluminum also has a vibration dampener and weighs I believe 1 lb less than the thirdgen aluminum.
The LS1 driveshaft is the preferred choice.
Old Nov 1, 2004 | 08:07 PM
85TransAm406's Avatar
Car: 1985 Trans Am
LS1 aluminum = 2.75" with vibration dampener.
thidgen = 2.5" but with a thicker wall thickness, making it stronger
Old Nov 2, 2004 | 01:00 AM
25THRSS's Avatar
correction, the third gen "1LE" shaft is 2.75 inches, whereas the LS1 shaft is 3 inches
sweet_87_iroc
Sep 25, 2015 10:01 PM
theshackle
Aug 23, 2015 03:49 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
MENINBLK
Aug 5, 2015 11:58 PM
