700r4- RPMs drop to idle if you let off of the gas
Old Nov 2, 2004 | 08:46 AM
Chadron's Avatar
Car: '91 Z28
Engine: L-98
I have a '91 Z with a L98 and 700r4. Mainly in third... when you are driving and let off of the gas the RPM's drop all the way down to idle, and when you hit the gas again the engine speed has to climb all the way back up before the car starts pulling again. The car has 140,000 miles on it but otherwise runs great. I even took it to the dragstrip ( which is 2.5 hrs. away) ran six times and drove home still with no other problems. I haven't changed the filter yet but I just wanted to run it past you guys as this is my first 700r4 as well as first f-body.
Old Nov 2, 2004 | 11:24 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
This is while the transmission is in third and the shifter is in O/D? Sounds normal to me.
Old Nov 2, 2004 | 11:33 AM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
In third gear thats not normal. In third gear it should STILL feel as if its in gear, like a manual in 3rd gear. Engine speed should stay up because of engine braking. You should feel the car slow down as engine drag slows the car down.
If it feels like the transmission drops into neutral then something isn't quite right.
I'll have to dig up the old trouble shooting chart, doesn't tell you everything, but its pretty damn good.
This may help you. Though I don't think it contains the information to help you figure out your problem.
http://sethirdgen.org/tranny.htm
Old Nov 2, 2004 | 11:43 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
Mine has and always has had no engine breaking in 1-D, but does in OD... so doesn't seem that out of the ordinary to me. If you start having that issue in OD then something is up...
91wtROH17's's Avatar
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
Ha, did you hear a big clunk before at any point? My trans does the exact same thing!! You most likely broke the part in the trans that holds the engine speed(kinda like a trans brake for downshifting and such) Could be like the piston or band? I am no tranny expert, but thats what I was told by a buddy.
Old Nov 2, 2004 | 11:55 AM
If he killed the band he would have lost 2nd and 4th gear. I should know, I killed mine.
Old Nov 2, 2004 | 12:00 PM
Car: 91Z
You could be very right. I honestly don't know exactly what causes the failure?? Either way something is wrong cause my trans is doing the exact same thing!! Any extra info would be great!!
Old Nov 2, 2004 | 12:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
In third gear with the selector in overdrive it is normal. The overrun clutch allows engine braking when the transmission is in manual third or below.
Old Nov 2, 2004 | 12:41 PM
My bad, when he said third, I assumed the selector was in D, and not OD.
Old Nov 2, 2004 | 01:31 PM
Pro Built Automatics's Avatar
If you have "no engine braking" when letting off the gas in the "D" position, then most likely the overrun assembly is the problem. Worn out overrun clutches, the sprag itself is gone, the overrun hub is broken, the overrun piston seals are gone, broken overrun piston, any of these can cause this problem. This requires the diassembly of the transmission to fix this.
Old Nov 2, 2004 | 01:37 PM
Car: 91Z
Thanks for the reply!! I am about to order a TC (Vig) from you, I was wondering if you have a problem shipping to Canada?
Old Nov 3, 2004 | 01:36 AM
No problem, it will be dropped shipped to you directly from Precision Industries.
Old Nov 3, 2004 | 06:56 AM
Car: 91Z
That's great, thanks!
Old Nov 4, 2004 | 06:31 AM
Chadron's Avatar
Car: '91 Z28
Engine: L-98
Thanks alot for the replies. I guess I am gonna have to call a friend and get the tranny from his crashed TA. LOL, with 140,000 miles I figured I would have to rebuild or replace it, I had hoped I wouldn't have to. Oh well, I really appreciate the info.
Chad
Old Nov 4, 2004 | 07:17 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
LOL... guess this shows how much I know about trannys!!!
Yeah... now that I really think about it, mine didn't always not brake in D... LoL... so thats what that clunk was about 2 years ago!!!
Old Nov 4, 2004 | 10:46 AM
Its not the fact that you don't know anything about them Chris. Its just that Dana knows sooo much more.......
Old Nov 4, 2004 | 11:19 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Prolly why I will be getting a Probuilt when mine decides to bit the dust!!!
jklein337
Sep 19, 2018 06:23 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
