changing from 700r4 to th400?????
Old Nov 12, 2004 | 11:40 AM
86interceptor's Avatar
Car: 86 Z-28 Police Interceptor
Engine: 305 but building a 350
Transmission: 700r4 with shift kit
I have an 86 z-28 with a 305 and a 700r4 and I am about to put a sbc 406 with a th400 with a 2400 rpm stall in its place. I am wondering if the th400 will bolt right up with the exception of the drive shaft lenth or if there is a lotof stuff I have to change???
Old Nov 12, 2004 | 12:23 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
You will have to find a way to mount the torque arm.. You'll also need a different crossmember, iirc. Might be able to kill two birds with one stone there.
Old Nov 12, 2004 | 12:46 PM
how would I kill 2 birds with one stone by finding a diff. crossmember?
Old Nov 12, 2004 | 01:48 PM
ericmac450's Avatar
Car: 1999 Camaro Z28
here ya go man...check it out!
http://www.spohn.net/product.cfm?productid=1301
Old Nov 12, 2004 | 03:16 PM
ljnowell's Avatar
http://www.bulkpart.com/Merchant2/me...y_Code=Teckpak
depends on what you want. If you buy the kit I linked to, you can install your th400, and use your stock driveshaft, torque arm, and crossmember. Stock speedo equipment too. Nothing has to change, but the trans itself. Its a real sweet kit.
Old Nov 12, 2004 | 05:18 PM
the kit you see in jegs and summit for 89 dollars to mount your torque arm to a turbo trans, what is it? how does it hook up, etc...?
Old Nov 12, 2004 | 05:26 PM
305q_ta86's Avatar
Car: 1993 Nissan 240sx
Engine: Turbo KA24DE
Transmission: 5 spd
Axle/Gears: 4.08 VLSD
Haha you shouldnt use that phrase on an f-body board.
Old Nov 12, 2004 | 05:32 PM
ljnowell's Avatar
If you search there are a couple of other people on here using it. You should seriously consider the link that I posted though, because it is becoming steadily more popular for a reason. Takes all of the headache out of the swap. Keeps everything the same as stock.
Old Nov 12, 2004 | 06:02 PM
I know it would be the best way to go, but iam looking for the cheapest right now because Ihave already broke the bank on the sbc 406 and the th400 with the 2400 stall. Plus I have my 700r4 sold as soon as Iget it out and the guy is not gonna want it with out the tail shaft on it, lol
Old Nov 13, 2004 | 06:27 PM
nolanr0413's Avatar
Car: Trans am
i too would like to know more info about this .I plan to swap a poncho 400 and a turbo 400 into my 85 ta .
Old Nov 14, 2004 | 01:05 AM
speedy3838's Avatar
Car: 85 iroc
Engine: 400 sb
Transmission: 350 turbo
I put a tpi 406 and a th350 in my 85 IROC and I used the kit from jeg's, I thought it was an easy swap but know I am looking for a driveshaft from a th2004r.
Old Nov 14, 2004 | 01:18 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
SPOHN is the only way to go
Old Nov 14, 2004 | 06:41 AM
speedy did you use the B&M or the Hurst kit? and was your th350 a short or long shaft? from waht I understand the long shaft th350 is the same lenth as the 700r4 so you can use the stock drive shaft.
Old Nov 14, 2004 | 11:59 AM
speedy3838's Avatar
Car: 85 iroc
Engine: 400 sb
I used th B&M kit with a short tail 350 turbo I heard that the drive shaft from a TH200 will work but I don't know yet
jklein337
Sep 19, 2018 06:23 PM
camaro11j
Sep 19, 2018 08:49 AM
someone972
Aug 30, 2015 12:52 AM
Thornburg
Aug 25, 2015 01:46 AM
TreDeClaw
Aug 14, 2015 06:58 PM
