shift kit?
Old Nov 16, 2004 | 04:33 PM
1984_Z28_305's Avatar
Car: 84 Z28
Engine: L69 305 H.O.
Transmission: rebuilt 700R4
shift kit?
what exactly is a shift kit and what does it do.
dont know anything about transmissions but i'm pretty good with the engine considering i'm only 16
Old Nov 16, 2004 | 06:44 PM
1badbowtie's Avatar
Car: 88 Trans Am
Engine: 305 tpi
simple answer is that a shift kit recalibrates the tranny to shift faster and more efficiently. i dont know a whole lot about trannys but mine had a shift kit in it when i bought it and it rips through the gears
Old Nov 16, 2004 | 08:46 PM
klumb15's Avatar
shift kits make your shifts really stiff too....mine hits in pretty good when it switches gears....it will improve the durability of your tranny too.
Old Nov 16, 2004 | 09:01 PM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
a shift kit will improve your shifts and extend the life of your transmission because it reduces clutch slippage in the transmission with its firmer shifts ....it will also reduce transmission temps
Old Nov 18, 2004 | 12:07 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
what kinda of shift kit would be good?? i was thinking about the B&M shift kit improver. also would it be a good idea to get my 700R4 tranny rebuilt?? just do everything all at one time..any ideas
Old Nov 18, 2004 | 01:50 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
In my opinion and others, Trans Go is the only way to go.
Kevin
Old Nov 18, 2004 | 03:21 PM
klumb15's Avatar
yea go with trans go, they have the best....i've heard stories of the other ones rippin your tranny apart ...definately not a good thing!!!
Old Nov 24, 2004 | 02:19 PM
InsaneIROC's Avatar
Car: 89 1LE IROC Z28
Engine: 364 Ci Ls2
Transmission: Mn12 T56
Axle/Gears: Borg Warner 9 Bolt With 3.70 Gears
Go with a Trans Go shift kit i have had 2 B&M shift kits in 2 different tranys and they are junk IMO now i use nothing but trans go
Old Nov 24, 2004 | 02:26 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
Another vote for Trans Go.
I have the Trans Go shift kit, .500" boost valve, and the Vette servo. This along with a rebuilt transmission is a nice thing to have.
Old Nov 24, 2004 | 06:27 PM
bjayshock's Avatar
Car: '87 SC, 91 RS
Engine: 305 4 bbl, 305 TBI
Transmission: 5 spd, 700 R4
Are B&M shift improver kits really that bad for the money? I would like to try one on my daily driver (91 RS tbi). It already gets pretty loose in the rain, i"m not looking to race it. I just want to make it more fun to drive, and maybe catch second.
What do you think?
Old Nov 24, 2004 | 08:54 PM
Having ridden in a car equipped with both kits I will STILL recommend the Trans Go kit over B&M any day of the week. The B&M was harsh, ALL of the time. Part throttle, full throttle. It was a nasty ride the whole time.
However, the trans go kit is WAY different. At part throttle its still firmer, but nowhere near as harsh. But open the throttle all the way and it shifts very fast, not jerky at all.
The Trans Go kit is just better.
Old Nov 24, 2004 | 09:00 PM
ljnowell's Avatar
Depends on what you like. I like the hard shifts all the time, I like my B&M. But I also run a th350. In a 700 I think Iwould probably run a Trans-go, but I dont think there is anything "wrong" with a B&M kit.
Old Nov 25, 2004 | 03:09 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
Transmission: 700-R4
Anyone has the part# for trans go.
Old Nov 25, 2004 | 08:06 PM
THEGENERAL's Avatar
http://store.summitracing.com/defaul...p&part=TRG-700
click that link
Old Nov 25, 2004 | 10:36 PM
That seems awefully cheap, are you sure thats not just the "corrective" kit, instead of the actual kit with instructions?
I haven't seen them go for less than $100, ususally $125 if you get the shift kit, video, .500" boost valve, and Vette servo.
Old Nov 25, 2004 | 10:51 PM
THEGENERAL's Avatar
yeah the kit i listed the first time was the wrong kit i changed it to the correct one ...sorry about that...
Old Nov 26, 2004 | 04:08 AM
Pro Built Automatics's Avatar
Go to http://www.700r4l60e.com/store/custo...&cat=28&page=1 this will give you the nice part throttle shifts, and firm WOT shifts. The B&M kit does not address the inherent problems (or any other problems for that matter) of the 700R4 transmission. The Trans-Go Shift kit & Performance Shift kit address the drawbacks to these units , & will solve them for the particular applications. You can "fine tune" these kits once you know what you are going to do exactly.
Old Nov 26, 2004 | 04:25 PM
whitecamrs's Avatar
Car: camaro88RS
Engine: 2.8l
what's the difference betwen the kits from probuits and from summit?
Old Nov 26, 2004 | 11:59 PM
I think the intermediate/reverse boost valve, and the 1-2 accumulator.
I ended up getting both of those with my setup and I'm not sorry I did. When someone rides in my car and I don't get on it, they don't know that anything is modified in the transmission. I took my father for a ride in my car and just tooling around town he though I did something wrong with the shift kit. It feels just the slightest bit firmer and faster at part throttle. But when I got further into the pedal it started shifting harder and faster till there was a very noticible difference between the stock and modifed shifts.
I'm really happy with my shift kit.
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
