help with t-5 with 400sbc
Car: 86 Z-28 Police Interceptor
Engine: 305 but building a 350
Transmission: 700r4 with shift kit
I have a 400sbc I want to put in an 88 iroc with a t-5 I just bought but I can't seem to find a fly wheel that will fit the t-5 bell housing and I also need to know what starter to get for it as well. please help I really want to get this car up and running, lol
Car: 83Z28 HO
Transmission: G Force 5 speed
Well at least on mine, everything bolted right up. Used the stock flywheel. Aftermarkets are available too.
I even used the same starter that came with the 305.....
are you saying to use the stock 305 flywhell? I thought the 305's were internally ballanced and I know the 400's are externally ballanced so how does this work?
Car: 83Z28 HO
You didn't mention anything about what kind of balance your engine had in your original post. I know there's options with externally balanced 400's but I can't think of them off-hand. I think there;s a counterwieght you can get that bolts to the flywheel, and you have to have a 400 dampener. Try searching....I've read about this before a few times.
yea mine is already built and is externally ballanced. I will try searching but I spent half the day searching before I posted lol. I could find that people had to use a special flywheel but they didn't say where to get it.
does anyone know where to get the ballance plate or what it is really called???? I have looked every where with no luck.
How about this?
http://store.summitracing.com/defaul...+plate&x=0&y=0
Or a new flywheel
http://store.summitracing.com/defaul...4925133+309345
Or a new flywheel
Car: 83Z28 HO
Originally posted by goofnrox
How about this?
How about this?
well if it works for a flexplate then it should work for a flywheel. if it balances the crank it balances the crank, right?
Car: `86 SS / `87 SS
Car: 83Z28 HO
Holy crap! I forgot that post!!!
I was even involved in it and forgot!
Remember that flywheel bolts are longer than flexplate bolts, and if you're going to add that weight to verify thread engagement.
I searched for half the day before I posted, I must not have put in the right search words but I did search, I always do.
I forgot to add that I am gonna get new flywheel bolts so that should not be a problem. thanks for everyones help. I just ordered the counter balance plate and new flywhell bolts from Summit, should be here right after X-mas
luvofjah
Sep 26, 2015 08:28 PM
