Please help.....9-bolt dilemma
Old Dec 30, 2004 | 08:56 PM
d21jim's Avatar
I am in need of some help....my dad has an 89 formula 350 with a 9-bolt and 3.27's. He has had the car for awhile now and it is baby. The posi unit went and we are having a hell of a time finding....a new posi unit...I searched and went on suggestion to check out 9bolt.com ....Miles only has 3.73s and it is my understanding that this ratio with a mildly modded tpi car would not be ideal.....he has no other rartios available.....Im really trying to get something for my father without buying a curtis strange unit or something like that.....is there anywhere else we can look so that we can finish restoring this car....?? All help is appreciated from both my father and I.. Thanks
Old Dec 30, 2004 | 09:46 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
just replace the posi or have the cones cut down and shimmed. that has nothing to do with changing gear ratios.
Old Dec 30, 2004 | 11:21 PM
d21jim's Avatar
where can I locate a new posi unit?
Old Dec 31, 2004 | 12:37 AM
CrazyHawaiian's Avatar
Car: too many ...
Its not very easy to find brand new units. I have not been able to find them myself. Best luck I've had is finding used units in the yards. Maybe look into rebuilding the posi unit. There is a nice tech article on the front page of the website regarding rebuilding the 9 bolt posi cones. Might be the best bet if you cant find a new unit.
Old Dec 31, 2004 | 12:53 AM
d21jim's Avatar
Thanks..I will check into that ......Im still looking...if you do find somewhere ...please let me know...Ill do the same...
Old Dec 31, 2004 | 09:31 AM
d21jim's Avatar
Anyone know of another place other than 9bolt.com
Old Jan 1, 2005 | 10:14 PM
d21jim's Avatar
I also tried Randy's Ring and Pinion and they seem to have taken the 9-bolts off their ordering?? ANyone know anything about this??
Old Jan 1, 2005 | 11:59 PM
Meatman's Avatar
Car: 1988 Formula
Engine: 355
Transmission: 6 speed
Stumbled across this a while back. Has lots of stuff.....
http://www.store.yahoo.com/ratech/79bogmax.html
Old Jan 2, 2005 | 02:45 PM
forums_suck's Avatar
Car: 1983 Z28
Engine: 383
I phoned them a month or so ago and was quoted 166 for 3.73 for yukon gears.I checked another place here in edmonton and they and they quoted me 250 cdn for the same gears.
Im sure any place that sells yukon gear sets will sell you gears for a 9bolt.
Id check ebay too theres usually some on there but there used
http://cgi.ebay.com/ebaymotors/ws/eB...category=42609
Old Jan 2, 2005 | 04:17 PM
f1ls1's Avatar
Car: 1999 F-1 Camaro Conv 1990 Iroc-Z
Engine: LS1/L98
Transmission: A4/A4
Axle/Gears: 3.23/3.27
It's my understanding that the new GTO uses the same 9 bolt rear as we do just a different housing. You may want to check out some of the GTO forums.
Old Jan 2, 2005 | 07:54 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
no, the gto is way way way differant. check some of my old posts, I took one apart and took pictures for every one to see. this was to put an end to that myth.
read drains post. there are other sources for those gears and diff. if you are haveing too hard of a time and decide on a differant rear then let me know. I will take it off your hands
here is the post you can see how differant the size and carriers are..
https://www.thirdgen.org/techbb2/sho...light=gto+rear
Old Jan 2, 2005 | 10:45 PM
red87iroc's Avatar
Car: No F-Body Currently :(
Engine: none
Transmission: none
Axle/Gears: still...none...(ugh)
Maybe this will help....
In the classifieds, I am selling a NEW IN THE BOX 9 bolt posi unit.
It is a 2 series, but you can just take the guts out and put them in your 3 series unit.
I am asking $150 plus shipping.
Contact me at jmvst23@comcast.net if interested.
Also, if I am wrong about taking the guts from a 2 series to repair a 3 series, someone please correct me. But I am pretty sure the guts are teh same for both.
Old Jan 3, 2005 | 12:32 AM
firedawg225's Avatar
Car: 1992 Camaro RS
Engine: 383 w/Holley Stealth Ram
Transmission: Pro-built 700R4
you can get parts at http://www.9bolt.com . Just got some parts from him today. he is sometime hard to get ahold of but he sells new 3 series carriers, gears and install kit for 895. you can also get used gears and other parts from hime to. the page also has some info on the 9 bolt. hope this helps
92GTA
Apr 9, 2016 07:39 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
TOXIC-Z
Jul 8, 2003 11:55 PM
yesfan2000
Apr 6, 2003 11:09 PM
joatrash
Mar 30, 2003 03:46 PM
