9-Bolt to 10-Bolt swap
Old Jan 3, 2005 | 04:39 PM
TurboSteve's Avatar
Car: 1987 Formula
Engine: 383
Has any one swapped their 9-bolt for a 10-bolt rear? Will the 9-bolt's disc brakes bolt right on? I've got an '89 Formula that needs a quick rear end rebuild, but don't know anyone near where i live that can perform this on a 9-bolt, not to mention getting rebuild parts for it.
Old Jan 3, 2005 | 05:33 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
i would leave the 9bolt in there its stronger,been proved a bunch!
Old Jan 3, 2005 | 05:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
PBR rear brakes, which I assume you have, are swapable from 9-bolt to 10-bolt, but 10-bolt backing plates are required and you'll likely need shims. Check the following link for the part numbers and general info:
https://www.thirdgen.org/techbb2/sho...hreadid=246768
JamesC
Old Jan 4, 2005 | 10:08 AM
TurboSteve's Avatar
Car: 1987 Formula
Engine: 383
Thanks James, excellent link and nice job on your brakes. I need to rebuild all four of my calipers as well. I know the 9-bolt is stronger, but i can build a new 10-bolt witth good axles and a new diff for about $300.
Do the required 10-bolt backing plates only come on disc brake-equipped 10-bolts?
Old Jan 4, 2005 | 10:19 AM
JamesC's Avatar
There were obviously some PBR factory ten-bolts, which have the appropriate backing plates, but the simpler approach, in my view, is to purchase new from GM. The cost was minimual, $13.34 per.
JamesC
Old Jan 4, 2005 | 01:43 PM
TurboSteve's Avatar
Car: 1987 Formula
Engine: 383
How much wider is the fourth gen rear than the third gen?
Old Jan 4, 2005 | 02:57 PM
Car: '88 Trans Am
Engine: 5.7L TPI
THE DIFFERENCE IS 4''..2'' each side..
Old Jan 4, 2005 | 03:09 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
Transmission: turbo 350
i swapped my 10 bolt brakes to my 9 bolt. i also swapped 9 bolt brakes to a 10 bolt. i never noticed anything different as far as backing plates go.
Old Jan 4, 2005 | 03:16 PM
JamesC's Avatar
The 9- and 10-bolt backing plates appear to be similiar, but the bolt pattern is different enough that they are not interchangeabe. See the above link for a comparison. The PBR's themselves, however, are interchangeable between the backing plates.
JamesC
Old Jan 4, 2005 | 05:16 PM
vejatabul's Avatar
Car: 1988 gta
Engine: 5.7
oh...... i see
to think of it, i never changed the backing plates. very informative
Old Jan 5, 2005 | 02:16 PM
TurboSteve's Avatar
Car: 1987 Formula
Engine: 383
James, if i buy the backing plates and shims, that's all i'll need other than the 10-bolt itself, right?
Old Jan 5, 2005 | 02:32 PM
JamesC's Avatar
Right. You'll be able to swap everything else from your 9-bolt: the hard lines, soft lines, the driver's side hose bracket, the e-brake cables and cable guides (without these, the pass side cable will probably fry on the intermediate pipe). I list the part numbers for all those above should you need them.
JamesC
ZMWojnar
Brakes
May 12, 2019 10:43 PM
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
