How much can a rebuilt 700R4 handle?
Old Jan 13, 2005 | 08:38 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I'm not talking about change the input shaft to a hardend one, I mean just a regular shelf rebuild kit. I am planning on making about 400-420hp and 450-460 ft/lbs of torque. The tranny I have now is slipping and the stall is really weak.
Will a rebuilt tranny hold on to that much power?
Old Jan 13, 2005 | 08:58 AM
ede's Avatar
ede
407 is about the upper limit on HP and 466 for torque
Old Jan 13, 2005 | 09:06 AM
Hmm. That sucks.
Old Jan 14, 2005 | 12:51 AM
daddy33's Avatar
Car: '85 Camaro
i've had a guy rebuild mine for $1000 which was for parts and R&R. He put new bands, corvette servo, etc.. and i have a 3500 stall. my 383 puts out about 500HP/TQ and havent had any problems. i've got the B&M megashifter and it snaps in every gear.
Old Jan 14, 2005 | 02:46 AM
Pro Built Automatics's Avatar
Go to http://www.700r4l60e.com/store/custo...&cat=19&page=1 This should give you what you need.
Old Jan 14, 2005 | 08:22 AM
Thanks man.
One more question. Are you able to change the ratios in the 700R4?
Old Jan 14, 2005 | 09:04 PM
chris718's Avatar
we are the only people in the country as of now building a 2.66 ratio first gear 700r4.and we sucessfully use our stage 1 700r4 at 450 horsepower,450lbsft in normally aspirated applications.
Old Jan 15, 2005 | 07:36 AM
chris718's Avatar
how much have others put through it?
Old Jan 15, 2005 | 10:07 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I am running about 335 flywheel horsepower and about 380 ft/lbs of torque through a near stock rebuild (in my garage) of a 1992 van 4L60(same thing as a 700r4 just called a 4L60(non E) in 1992. It is in a Chevy Van that I have beat on for 15,000 miles with no problems yet. The only thing special in it is the Vette 2-4 Servo, Vette TV boost valve, Transgo Corrective shift kit, and modified the governor for 5,500 rpm upshifts with a B&M kit. Oh and I have a 2,000 rpm lockup converter meant for a 4.3 S10 (Actually stalls @ 2,500 rpm in the van). All I have to do is mash the pedal and let the transmission do the work.
Has survived my heavy foot, track and dyno abuse, towing my 5,500# boat, numerous cars, climbed Ratan pass with my foot on the floor pulling something a couple of times. It still chirps the tires (P255-70-R15s with 3.08 posi) on every WOT 1-2 shift. Hasn't even warmed the fluid up enough to turn it gray.
Old Jan 15, 2005 | 11:03 PM
chris718's Avatar
THEY SAY TTHE INPUT HOUSING is the weak link however we install new ones in our stage 2s and never break them
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Veaceonee
Sep 29, 2016 08:15 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
scottmoyer
Sep 7, 2015 07:06 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
