Junk 700R4
Old Jan 16, 2005 | 01:17 AM
RebelRacer's Avatar
Car: Bitchin' 92 RS
Junk 700R4
Jus thought I'd chime in and let you guys know my tranny lost Dirve and OD today. Not too much of a loss, it slipped pretty bad. But lucky for me, i've got a spare, gonna put a trans go shift kit in and fill it up with B and M, maybe it will shift harder than the last one. Well, just thought i'd let someone know my plan, what do you guys think?
Kyle
Old Jan 16, 2005 | 09:21 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
That is what they usually do. 3 and 4 go away first. There are better clutch packs for beefing this weak link up when it is rebuilt.
Old Jan 16, 2005 | 12:02 PM
chris718's Avatar
regardless of the kit you use you must open the third clutch oil supply hole to the 2/3 shift valve hole in the plate to .170"and the third clutch oil feed hole in the plate from the shift valve to the input housing to .170' all youll fry them again in short order.this should be considered mandatory.the trans go kit orifices 3/4 clutch oil on a 4/2 or 3/2 kickdown at the spager plate and this is dangerous for the clutch pack and band at high throttle angles.there must be 2 holes and a checkball at the 3rd accumulator transfer in the plate.although there tech is great i feel that it is wrong in a hi output application and came to this conclusion after studying this very complex circuit for many years.the transmission has three other bleed of points for this circuit once supply oil is shut off and all three together are not as efficient as the original 2 hole design used by gm.
Old Jan 16, 2005 | 12:07 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Chris, any chance you can post a photo of the plate mods you describe? If not can you give a little more detail(circuit number, etc). I appreciate the info. I just don't wanna screw it up. Thanks, Pete
Old Jan 16, 2005 | 12:26 PM
chris718's Avatar
im not good at that but if you call me or email me a pic of the late seperator plate id be glad to tell you which ones otherwise ill have trouble posting it.thanks.
Old Jan 16, 2005 | 12:27 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
Thanks chris, I don't know how to send a picture but I will figure it out. Thanks, again
Old Jan 16, 2005 | 12:35 PM
chris718's Avatar
if you have a manual ill tel you the appropriate hole numbers and sizes
Old Jan 16, 2005 | 12:37 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
I have all of the atsg books so that should help.
Old Jan 16, 2005 | 05:50 PM
brutalform's Avatar
Hi Chris...I have the picture from the ATSG manual, Flooguy wants to send. I cant send it to this site either. I cant figure out how to get the pic. small enough. I can e-mail it to you if you like. Thanks...Tom
Old Jan 16, 2005 | 06:29 PM
chris718's Avatar
no problem.ill reply with the appropriate hole sizes and then we can send it to the other guy.
Old Jan 16, 2005 | 06:56 PM
brutalform's Avatar
Ok Im gonna try to send it...Here it is.
nope still too big
Old Jan 17, 2005 | 01:51 PM
brutalform's Avatar
try again
File Type: bmp
Old Jan 17, 2005 | 02:37 PM
gearhead0384's Avatar
Car: 1989 Camaro IROC-Z
Engine: L98 350 TPI
Transmission: Built TH-700 R4 (Vilgilante 2800)
Axle/Gears: 9 bolt w/ PBR's
now its too small
Kevin
Old Jan 17, 2005 | 03:28 PM
brutalform's Avatar
I know, Im a dummy when it comes to this....LOL
Old Jan 17, 2005 | 05:30 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
Resize it down to about 640x480 and save it as a JPEG... You must however select the quality (may be under an options button) as about 60-70... It will still come out quite readable...
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
92projectcamaro
Sep 29, 2015 07:07 PM
mfp189
Sep 27, 2015 09:25 AM
armybyrd
Sep 26, 2015 03:37 PM
6998poncho
Sep 25, 2015 02:56 PM
