Trans lines
Old Feb 6, 2005 | 01:28 PM
SilentBob's Avatar
Car: it doesnt really drive right now
Engine: 383
Trans lines
Hey just thought I would throw out a quick question to the forum before I totally lose my mind. I am trying to get the trans lines hooked up so I can start the car next Saturday and to save my blankity blank life I can get the upper line connected. I have tried just about everything I can think of and just cannot get a tool in there to work on it.
I have even tried one of those "crow foot" wrenches. Anyone have any tricks of the trade?
Old Feb 6, 2005 | 01:30 PM
ede's Avatar
ede
it can be done, i usually use a short open end wrench for most of the job then a flare nut wrench for the finial torque
Old Feb 7, 2005 | 01:12 AM
SilentBob's Avatar
Engine: 383
Found the problem.... The old line for some reason had messed up threads that only looked like they were OK. I put a new line in and that took care of things.
Got creative with the tools though. I found that a short open end wrench and a few minutes with a 3lb sledge and a vice can yield a very useful tool. A 90 degree open ended wrench that ends up being more compact than anything else I had.
Old Feb 7, 2005 | 02:16 PM
Notplayn's Avatar
Car: Depends on the day!
Engine: the kind that runs on money
Transmission: One that holds up, I hope
Hello, I am having the same problem. I could attach the top line but not tighten it. And I can not get the bottom line on at all. I thought about unbolting the trans and lowering it for access. Also does the upper line attach to the upper spot on the radiator. Thanks.
Old Feb 7, 2005 | 05:11 PM
SilentBob's Avatar
Engine: 383
Lowering the transmission helped me out a lot.
Old Feb 7, 2005 | 07:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Yes, upper to upper and lower to lower.
I got rid of the hard lines and used braided hose so I can connect the fittings on the transmission before raising the transmission.
Old Feb 8, 2005 | 08:30 AM
Notplayn's Avatar
Thanks for the info and the good idea..
Old Feb 8, 2005 | 12:40 PM
Forshock 85TA's Avatar
Car: 85 Trans Am
Engine: 350 (CCC QJet)
Axle/Gears: 3.08 9 bolt
I use a pipe cutter and shortened the hard lines, cut 2" inches off each and used a braided line to reconnect, makes install a lot easier. Also works good for an external filter
84z96L31vortec
Aug 20, 2017 12:16 AM
TheJoeY88
Dec 31, 2016 07:30 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Leggman1
Aug 6, 2015 04:15 AM
