Throttle valve cable to throttle clip broken
Old Feb 6, 2005 | 02:15 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
The plastic clip that connects the throttle valve cable to the throttle body broke. Just wondering if this part is available at parts stores? The original clip is slid over the wire between the adjustment bracket and the end of the cable that has a permanent metal "lug" on the end to keep the clip from falling off. Do they make a replacement that will clip "around" the end of the cable? I really hope i dont need to replace the entire cable.
Just looking for suggestions before i run out to the parts stores.
Old Feb 6, 2005 | 07:31 PM
TekViper's Avatar
Engine: 3.1L v6
well, came up empty handed at pepboys and autozone. going to try a transmission shop tomorrow, hopefully they have something. For now i just connected the cable to the throttle with some metal wire until i can find a permanent solution. Here is a picture of the broken clip. Do they make a replacement clip that will slide over the lug of the cable? or will i have to cut the lug off and crimp something else on the end?
Attached Thumbnails Throttle valve cable to throttle clip broken-c-documents-settings-anthony
Old Feb 6, 2005 | 08:33 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If you cannot find a replacement end, they are about 25 bucks at the dealer. May be worth it so you don't have to run all over town! Just my 2 cents
Old Feb 6, 2005 | 10:09 PM
TekViper's Avatar
Engine: 3.1L v6
25 bucks for that little clip? ouch. Do you know if it will slide over the "lug" of the cable, or do i have to cut the lug off the cable and crimp some other kind of stop onto the end?
Old Feb 6, 2005 | 10:23 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
I was not very clear in my post. What I meant to say was the complete cable fron the plastic clip all the way down to the trans is about 25 bucks. Not a bad price really.
Old Feb 7, 2005 | 01:53 PM
TekViper's Avatar
Engine: 3.1L v6
I tried 2 tranny shops, no luck finding the clip seperately. Looks like ill need to buy the cable. oh well, thanks for the help.
Old Feb 8, 2005 | 04:02 PM
TekViper's Avatar
Engine: 3.1L v6
well one of the transmissions shops was able to locate a replacement clip for me. it is designed so removal of the cable is not nessacery. Great time saver and you dont have to worry about rigging something up that might fail later. heres a pic. Just thought this might be helpful if anyone runs into the same problem.
Old Feb 10, 2005 | 10:55 PM
di11avou's Avatar
Car: 1988 Camaro
Engine: 305ci TBI
When mine broke I found a new one at NAPA. I hated paying $5 for that tiny chunk of plastic but you have to have it.
9192camaro
16
Feb 3, 2019 12:21 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
lakeffect2
Aug 23, 2015 08:44 AM
timonator
Aug 13, 2015 11:27 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
