T-5 replacement
Old Feb 10, 2005 | 10:13 PM
CrashRS91's Avatar
T-5 replacement
I broke my t5 in my 91 rs and I was looking for a t56 but I am really having problems finding one for a reasonable price. So I am now resorting back to putting a t-5 back in. Anyone know what years or what I should look for in a used? can I cant a 4th gen t-5? will the 90 down with out the electronic speedo's work? any assistance will be much apprechated.
Old Feb 11, 2005 | 03:27 AM
scubas_90rs's Avatar
Car: 90 RS, 83 z28, 85 ranger
Engine: none, 350, 2.8
Transmission: none, t-5, 5-speed
if i rember right the 4th gen t5 is the same as a 3rd gen t5. if you a v6 it should work just fine. if not you will have to get a different clutch. some one correct me if im wrong.
Old Feb 11, 2005 | 04:26 AM
CrashRS91's Avatar
I have the 305 v8 so does that v6 4th gen camaro have the same t5?
Old Feb 11, 2005 | 12:44 PM
the trans itself is the same but the input shaft is different. the spline count is different if i rember correctly. if you went with it you would have to get a custom made clutch.
Old Feb 11, 2005 | 07:41 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
what did you break? where are you located? im going to be doing a g-force setup for my car, and dont see a point in tearing up my perfectly good trans.
Out-Cast
Dec 31, 2015 04:40 PM
Dan Hubbard
Aug 12, 2015 09:05 PM
marcusaw
Aug 10, 2015 08:13 AM
Fronzizzle
Aug 9, 2015 01:15 PM
