Unbolting tranny from engine
Old Feb 10, 2005 | 08:49 PM
Scotty562's Avatar
Car: 2001 SS Camaro
Axle/Gears: I should know this
I bought a old 84 to learn with for 250 bucks. The only thing wrong with it is a spun bearing.
So, i'm in the process of removing the engine, and I got to the tranny. Then I removed the piece that reveals the converter and starter.
Now i'm just at a loss for what to do next. How do I get all the bolts out?
I looked in the chiltons book, but they don't explain the procedure very well. Links, or manual explanation would be great!
Thanks, guys.
Old Feb 10, 2005 | 11:26 PM
Jim Berry's Avatar
Car: '86 Trans Am
Engine: LG4
Axle/Gears: 3.70 Posi disc 9 bolt
Get a Haynes manual. They explain stuff simpler than Chiltons. I use Chiltons for the wiring diagrams and the Haynes for when I want to actually fix stuff. Not bad for a British company.
Jim.
Old Feb 11, 2005 | 12:22 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
get out some sockets, a bunch of extensions, and a swivel end. make sure to take the converter bolts out as well. just be patient and try not to yell too loud when the darn swivel doesn't cooperate and you bust you knuckels on the tranny pan.
Old Feb 11, 2005 | 08:38 AM
Scotty562's Avatar
Car: 2001 SS Camaro
How many bolts should there be? I can only see 3, there has to be more.
Old Feb 11, 2005 | 08:57 AM
SPIKE's Avatar
Car: 86 CAMARO
Engine: 92-350 +.030
Transmission: 86-th400
just did this not hard. disconnect drive shaft. put jack under tranny oil pan. unbolt exhaust hanger and torsion bar mount. put piece of wood between chassy and top of torsion bar because it will slam bottom of car. remove cross member. i removed my distributer so i could get to top tranny bolts with one of those new ratchet combo wrenches. worked great. the bottom bolts with socket. yes converter has only 3 bolts. also make sure you disconnect tv cable. one other trick is to duct tape a zip lock bag to end of tranny where drive shaft came out of so fluid doesnt go every where.
Old Feb 11, 2005 | 01:29 PM
vjo90RS8's Avatar
Car: 2002 Z28
http://www.kyfbodies.org/tech/trans_swap/trans.html
this is the article i used when removing my tranny
Old Feb 11, 2005 | 03:20 PM
Scotty562's Avatar
Car: 2001 SS Camaro
Can I just simply unbolt just the engine from the transmission, or must I disconnect the tranny and remove the whole works?
Or, would it be even easier just to pull the engine and tranny out together?
Old Feb 11, 2005 | 06:40 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Yup, remove the hood, driveshaft, radiator, and take all the connections off the engine and tranny like hoses and lines and wires, etc. Then undo the mounts, support the tranny and pull both out from the hood while watching out for the distributor or remove it first.
Old Feb 11, 2005 | 09:18 PM
SPIKE's Avatar
Car: 86 CAMARO
yes you can. but i had to remove the main pully oh the ballancer to clear the front clip.
sweet_87_iroc
Sep 25, 2015 10:01 PM
gta90
Sep 15, 2015 04:00 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
