aftermarket Slave for t-5
Old Feb 13, 2005 | 01:58 AM
F-Bobby's Avatar
Car: 1989 Formula 350
Engine: Stealth Rammed 350
Axle/Gears: 3.45 9 bolt
Hey i was wondering if there were any aftermarket companies that made a slave cyl for a t-5. I did some searching and i found that there is a company called Brake Best, that makes a slave cylinder that has an aluminum main body. Well i also saw that it is distrubted through o-rilleys stores. We dont have thsoe around here. Just Autozone(which doesnt stock them), VIP (which i bought one from and it broke while i was bleeding it) and Napa (which has nothing). Is there any other aftermarket possibly performance companies that would make or sell them? I would prefer not to put a stock one back in if i could avoid it. thanx.
Old Feb 13, 2005 | 11:33 AM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
get one for a LT1 T56..93 to 97 will work....its an aluminum body with a steel braided line...the line is also longer
Old Feb 13, 2005 | 06:43 PM
F-Bobby's Avatar
any idea how much that is gonna run me?
Old Feb 14, 2005 | 07:14 AM
f-crazy's Avatar
Engine: CARBED LT4
Transmission: MK6
ahh sorry about that....its between 125 and 150
Old Feb 15, 2005 | 04:16 AM
F-Bobby's Avatar
For just a slave cylinder??? DAMN!
Old Feb 20, 2005 | 01:20 AM
F-Bobby's Avatar
well i couldnt find an Aftermarket one in the time i had. So i got a replacement from NAPA. Man this thing is like night and day. I think my old slave must have had a leak to it, cause my clutch pedal is twice as firm as it used to be. Anyone whos running a slave with decently high miles i reccomend gettin a new one. You will definately notice a difference.
Old Feb 20, 2005 | 05:32 AM
84 Z-28 350's Avatar
Car: 84 Z-28 Camaro, 2022 2500 silverado
Engine: 383
Axle/Gears: richmond 3.73, eaton posi
I have another queston allitle off subject, I want to swap to A T-56, but I would like to keep my T-5 master cylender(too hard to take out again, and I heard the pushrod end that attaches to the pedels is diffrent), is it possable to just take the roll pin out that holds the line to the master cylender and switch out the line and slave cylender, I also, heard there's no bleeder screw on it like the T-5's slave cylender has, how do you bleed it?
Old Feb 20, 2005 | 10:53 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
I have one from Autozone. It is made by a company called Brakeware and it is machined aluminum with a bleeder screw. Pretty sure the part comes with a lifetime warranty. So far mine has seen almost two years of hard 6000+ rpm shifts with a centerforce clutch at the dragstrip and no problems. I think it is a great piece. I wrote a thread about this last year with the part number.
Old Feb 21, 2005 | 09:16 AM
F-Bobby's Avatar
thats really weird that a lot of people are saying they are gettin them from autozone cause i went to mine and they said they dont even carry the slave cylinder. hmmm....
Old Mar 28, 2005 | 05:40 PM
C h r i s's Avatar
From left to right: Brakeware 10380, Tru Torque SC37821, stock '93 and up slave:
Made in Italy:
I will be using the hose from a '93 up because it is braided and has the same hose ends.
Chris
Old Mar 28, 2005 | 11:03 PM
Engine: 383
dose the 93 up and a 84-92 use the same hose ends???
Old Mar 29, 2005 | 08:03 AM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
The LT1 one is the entire slave, master, and resevior. Wholesale at GM plus tax is around 135. It is pre-bleed too, incase you are working byself as I did a week ago.
Old Mar 29, 2005 | 08:48 AM
C h r i s's Avatar
Yes the braided '93 up uses the same hose ends but be warned there is a restriction in the line that needs to be drilled out. You see it refered to as the "drill mod".
I did this Saturday - a 1/16" drill bit would not pass through this restriction, so I drilled it out to 7/64". Click the link that shows the "discarded line cut off" here: http://www.montecarloss.com/ls1montecarloss/August.html
To quote John Bzdel: "clutch hydraulic line to the slave cylinder has a restrictive orifice which limits fluid travel down to ~1/16" and can cause issues with apparent grinding of 2nd & 3rd gears at high RPM since the clutch may not fully dis-engage or engage fast enough during shifts."
Chris
Old Apr 25, 2005 | 09:44 PM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i looked up the slave on autozones website (40.99 BTW) and saw they offer a master too, does anybody know if it is an aluminum piece too? does anybody know if the braided line itself is available from gm?
Old May 1, 2005 | 06:33 PM
TexasLT1's Avatar
Car: '92 RS
Chris
Thats only for the LS1 T-56. LT1 T-56 does not have the same restriction in the line.
*Edited for misinformation*
Howe Racing Enterprises at www.howeracing.com has a hydrualic throwout bearing for the T-5.
Old May 1, 2005 | 06:43 PM
Car: 91 Camaro RS
Anyway, an LT1 slave cylinder will not work with a T-5. The T-5 uses a push-type slave cylinder, while the T-56 uses a pull-type.
Can you tell me how I shift gears then? I'm using LT1 slave and master with my t-5.
Old May 1, 2005 | 11:58 PM
TexasLT1's Avatar
Car: '92 RS
well alright then. I'll admit when I'm wrong.
Sorry, didn't realize how the LT1 clutch throwout worked. I thought the slave cylinder pulled the throwout yoke.
Old May 2, 2005 | 05:32 PM
C h r i s's Avatar
The LT1 Master/braided line/slave is GM 12559912. My GM 12559912 had a restriction that would not allow a 1/16" drill bit through. I drilled this out to 7/64".
My G-body Doug Nash 4+1 swap page is here
Chris
Old May 3, 2005 | 01:33 AM
TexasLT1's Avatar
Car: '92 RS
ugh, I hate misinformation, and for once I'm the source of it.
let me put it this way then, I've only heard of the restriction causing problems in LS1's, never heard of shifting problems due to it in LT1's.
Old Feb 8, 2006 | 02:46 PM
kamu's Avatar
Car: 84 Z28
Engine: 400
Transmission: tex racing t101a
Axle/Gears: 4.56
Chris
I have looked this part up at gmdirect and can get it for $98.00 Is this a aluminum slave or is it plastic it is to hard to tell from the pictures
Old Feb 9, 2006 | 06:10 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Would something like that LT1/T56 slave setup with with a T10? How does it mount to the bellhousing? I'm trying to figure out how to use a hyd linkage for my '82 T10 setup w/o getting an aftermarket bellhousing.
Old Feb 10, 2006 | 11:24 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
Been there, done that, got boxes of unused parts from experimenting.
The length of travel needed on the old manual linkage fork & bell is greater than the travel of the T5 slave cylinder & master combination. I ended up going with a Mcleod master cylinder in hopes of overdriving the slave since it has a larger bore than stock, no dice. I now waiting on a custom made hydraulic TO bearing from Mcleod, not cheap.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
