Question about TV cable and transgo Kit
Car: 89 Camaro RS
Engine: LO3
I just bought a transgo shiftkit for my 700r4 and I would like to know if i will gain anything from getting a new braided TV cable since I broke my old one or should i just buy a stock replacement?
http://www.bowtieoverdrives.com/cata...BCAT&CATID=WA1
Car: 91 Camaro RS
Engine: 350 bored .030 carbed
Transmission: t5
Axle/Gears: 3.08
pretty sure that the braided TV's are mainly for looks, i would go with a stock replacement if u want to save some money.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
There aren't any "gains" to be realized from the TV system, either it's installed right with the correct geometry or it's not.
Car: 89 Camaro RS
Engine: LO3
So I installed my tv cable, by the way its a B&M adjustable tv cable, and I was hoping to get it running right. The problem is, is that when I take off I pull out of first gear right, but when I am coming from second to third, the car seems to rev and not go anywhere. Every other gear is fine. It also seems to shift a little late overall. Does this mean that I burnt something inside my transmission, or does it just need simple adjustment. If adjustment is needed, how can I go about doing that. PLEASE HELP...I'M LOST!!!
Car: 89 Camaro RS
Engine: LO3
Car: 89 Camaro RS
Engine: LO3
Car: 89 Camaro RS
Engine: LO3
Car: 89 Camaro RS
Engine: LO3
Car: 1989 Trans Am GTA
Transmission: M28 T56
There is a right way and a wrong way to adjust a TV cable. The right way keeps your trans happy, the wrong way burns it up.
Car: 89 Camaro RS
Engine: LO3
Actually the B&M cable was only $5 more than the factory one.
also its only does that when downshifting or when there's too much throttle being applied. they car did run better this morning but its still doing it a little bit I'm hoping it just needs adjustment.
Do you guys think my tranny is doomed?
Thanks for your help everyone
I've been where you are.
SEVERAL times.
Start saving now, if the fluid level is correct, and the TV cable correctly set, but the transmission still acts odd then you have to face the truth. Your transmission is going south, you need a rebuilt or new transmission.
SEVERAL times.
Car: 89 Camaro RS
Engine: LO3
At anywhere between mid-throttle to full-throttle is when 2 and third flare up. It's so touchy that I drive as if a cop is behind me all the time.
dhonda200
Aug 11, 2015 11:50 PM
