what SERVO and SJIFT-KIT to use???
Old Feb 13, 2005 | 11:47 AM
Crusin' 1980's's Avatar
Car: 1988 SC Camaro
Engine: 305 TBI
Transmission: 700-R4
I’m trying to figure out what to start looking into for shift kits and servos…
Do you know what is the best type of Servo and shift kit to use for a 305 TBI camaro? (700-R4). Is a Corvette Servo better or one from TCI or JET a better choice? Also, how about a Shift-Kit? TransGo makes one for 139.69, B&M has one called “Shift Improver Kit” and another one called “Transpack” for about the same price. Which setup will give me the firmest shifting? (w/o any real expensive setups)
Old Feb 13, 2005 | 12:28 PM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
I have the trans-go shift kit, corvette servo and boost valve. All I can say it shifts really hard. You don't even need to be in the throttle hard for the tires to break loose from the 1-2 shift.
Old Feb 13, 2005 | 04:35 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
i have a corvette servo and i already have the transgo shift kit that i need to install. but man the servo alone makes a big difference on the 1-2 shift. and its so easy to install too, took me about 30 min to do. get that first bro.
Old Feb 13, 2005 | 06:18 PM
Car: 1988 SC Camaro
Engine: 305 TBI
does the transgo shift kit improve shifting through all the gears....do i need to shift manually with the kit? how does shifting manually effect anything?
Old Feb 13, 2005 | 07:22 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
the kit comes with the servo, if I had been smarter I would have ordered ordered the kit from the get go. My car shifts much better with the vette servo alone.
Old Feb 13, 2005 | 07:38 PM
Car: 1988 SC Camaro
Engine: 305 TBI
are you saying that the TransGO kit comes with a performance servo?
Old Feb 13, 2005 | 08:31 PM
Yes, the kit comes with the corvette servo
And you dont have to shift the car manually, you can if you want thought since it will hold the gear your in as long as you want.
Old Feb 13, 2005 | 08:34 PM
IrocZS383's Avatar
Car: 1986 Camaro
Engine: 357
the trango kit from www.pro-built.net comes with every thing for $148. It comes with the shift kit, the corvette servo, the .500 boost valve, the .296 intermediate boost valve, and the 1-2 accumulator setup. It is the kit Dana pieced together himself.
Old Feb 13, 2005 | 10:34 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Cool, that looks like the setup I'm looking for
Old Feb 14, 2005 | 07:32 PM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
I have a question about the different boost valves. Do those allow you to shift into 4th at full throttle??
Old Feb 14, 2005 | 08:06 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
No, basically the larger boost valve will give you more pressure.
If you want full throttle upshift into OD you'll have to look into a sleeve and plunger upgrade for the valve body. (b4c upshift valve kit) you should find tons of info on it in a search
Old Feb 14, 2005 | 08:37 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
B&M makes a 4-3 kickdown kit BMM-70242 $41 from www.summitracing.com
https://www.thirdgen.org/techbb2/sho...m+kickdown+kit
basically the 2 kits available to do it and the differences and whatnot. Dunno where to get the GM part
Old Feb 14, 2005 | 09:23 PM
Engine: carbed 383
I work at a GM dealer and they told me I can no longer order the kit that was in the B4C because it has been discontinued... go figure
Old Feb 15, 2005 | 12:48 PM
Engine: 383 SBC
Might check out www.gmpartsdirect.com Maybe they have a few left there. I think the part number is 8673948
Old Feb 15, 2005 | 02:17 PM
Car: 1988 SC Camaro
Engine: 305 TBI
so, does the shift kit alone provide for better shifts through all the gears? or just when the car shiftes from 1st to 2nd??
Old Feb 15, 2005 | 06:20 PM
Engine: 383 SBC
Yes.
Basic TransGo Kit:
Corrects/Reduces/Prevents:
3-4 clutch failure.
Late or no 4th gear.
Soft, bang or slide bump 1-2 shift.
2-3 cutloose (spinup).
TV cable will not adjust properly.
The more expensive kit offers a larger boost valve for a little more pressure and a few other parts.
Basically the TransGo kit will firm up all shifts with the larger valve and corvette servo, let you hold 1st gear longer (won't try shifting you out of it automatically), and help prevent few things like RPM flare from 2nd to 3rd during shift. (On my OEM it was about a 300 or 400 rpm flare.)
I'll just throw a disclaimer in here that a shift kit isn't a fix for problems like slipping clutches or missing gears.
Old Feb 16, 2005 | 05:19 PM
Car: 1988 SC Camaro
Engine: 305 TBI
Old Feb 28, 2005 | 07:55 AM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I was looking at the Transgo kit on Jegs/Summit and it goes for about $138 whereas the Probuilt kit with accumulator is $148.
Does the probuilt kit include any extra items like intermediate boost valves or is the probuilt kit the same thing as the transgo kit but with an accumulator.
Thanks.
Old Feb 28, 2005 | 08:12 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Just give Pro-built a call. You can go to their web site and get their phone number or send them an e-mail. Dana will answer all of your questions and the answers won't be second-hand. He's been very responsive to several on this site and helped me out.
Frozer!!!
Jan 19, 2024 04:55 PM
lt1z350
Sep 29, 2015 01:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
italiano67
Sep 22, 2015 08:42 AM
scottmoyer
Sep 7, 2015 07:06 PM
