non lock up 27 spline 700r4
Car: 89 Formula
I have been looking for a new converter and all I can find is lock up converters. Im not running a computer or want to run lock up.
So is there any company that has non lock up for the 27 spline tranny or can I run a lock up converter but not use it, will it hurt anything?
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
give the guys a holler at www.atiperformanceproducts.com they will point you in the right direction. and just happen to have some of the best converters on the planet.
Engine: 7.0L
i am not sure, but i heard it's not advised to run a non-lockup converter in a lockup tranny.
Originally posted by Duke901
Ya, im not to sure what to do, i know the 30 spline 700r4 has converters that dont use the lock up. Iam starting to think i might just go with a th350
Go to http://www.700r4l60e.com/store/custo...&cat=49&page=1 this will give you a 27 spline non-lockup torque converter. You will need to add a Trans-Go non-lockup valve to the front pump (this requires pan removal) & remove the checkball & capsule from the input shaft, that is it. This TC weighs about 12 pounds less, produces more part throttle torque, runs cooler, etc. Better gas mileage around town, and a slight loss in freeway gas mileage, about 1/2 MPG.
Go to http://www.700r4l60e.com/store/custo...&cat=40&page=1 this will give you the stall you want. Let me know?
83 Crossfire TA
Sep 8, 2015 12:06 PM
