swapping rearends
Old Mar 4, 2005 | 12:14 AM
SchwarzCamaroRS's Avatar
swapping rearends
im going to be swapping my stock 2.73 rear for a 3.42 rear out of a 1991 Z28. Ive got a 700R4, what do i need to make my speedometer read correctly... speedo gear? which one?
Old Mar 4, 2005 | 12:17 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
16T Blue (8640518) Drive, 44T Dk. Gray (25513051) Driven
Old Mar 4, 2005 | 12:21 AM
anything else i need to swap out? or just those two parts?
Old Mar 4, 2005 | 05:30 AM
panman79's Avatar
will those same speedo gears work in a 4l60e trans?
Old Mar 4, 2005 | 11:49 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Depending on what gear you have now, you might need a new housing.
The same gears will work in a 4L60E with the same gearing and same size tires.
Old Mar 4, 2005 | 12:22 PM
Benm109's Avatar
Car: 1991 Chevy Camaro
Engine: 305 TBI
Sorry to interrupt, but Apeiron, how did you figure that out? From online gear calculators or...? I'm doing the exact same thing (switching from 2.73 to 3.42 gears) and from researching past posts everyone stated that you need a 15T gray drive and a 41T yellow driven gear. Just curious.
Old Mar 4, 2005 | 12:45 PM
panman79's Avatar
Ben, do you think the speedo gears will work in a 4l60e also?
Old Mar 4, 2005 | 01:13 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I used a gear calculator I wrote a few years ago. It gives the closest combinations possible without reading high. It also spit out a combination with a 15T drive that may have used the 41T driven, I don't remember. In any case, 16 / 44 = 0.3636 and 15 / 41 = 0.3659... the difference between the two ratios is pretty small.
Old Mar 4, 2005 | 02:18 PM
Benm109's Avatar
Engine: 305 TBI
OK, I understand now. I realized that the 2 different combinations weren't that much different, but I just wanted to make sure I wasn't missing anything. Thanks.
Old Mar 4, 2005 | 02:21 PM
im just changing the rear out, same tires, same 700R4... those two gears is all i need, correct?
Old Mar 4, 2005 | 04:32 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You might need a new VSS housing to match the size of the new driven gear.
Old Mar 4, 2005 | 11:15 PM
how much? and can i get one from gmpartsdirect.com what part number?
Old Mar 5, 2005 | 11:15 AM
Benm109's Avatar
Engine: 305 TBI
From what I understand (through searching), you will not need a new VSS housing. I also asked this question a week or 2 ago just to make sure, check it out:
https://www.thirdgen.org/techbb2/sho...hreadid=280805
Old Mar 5, 2005 | 11:31 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Actually, now that I look, it appears that the 25513051 I gave is actually the P/N for the gear and sleeve unit together.
Old Mar 5, 2005 | 01:18 PM
sweet, thanks guys
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
86White_T/A305
Aug 17, 2015 12:16 AM
