Pulling engine
Old Mar 8, 2005 | 12:44 PM
Scotty562's Avatar
Car: 2001 SS Camaro
Axle/Gears: I should know this
Pulling engine
I'm attempting to pull the engine out without the transmition. I removed the cover exposing the converter and I also removed 4 bolts that appeared to be attached to the engine.
What comes next?
Chiltons says to remove the tranny crossmember, chiltons guide is also to remove the tranny. I just want to pull the engine with the least hassle possible.
Old Mar 8, 2005 | 12:55 PM
Siegel1719's Avatar
Car: 85 Iroc
Engine: 461
Transmission: Turbo 400
Drain ALL fluids besides trans
Disconect all hoses/ wires
Disconect PS/AC from motor
unbolt the 3 or 4 torque converter bolts
Unbolt motor from trans
unbolt motor mounts
Double check all hoses/lines
pull motor up/forward/up out
Of course this is just a quick overview.
Old Mar 8, 2005 | 01:03 PM
Scotty562's Avatar
Car: 2001 SS Camaro
done
on the engine, not trans correct? if so, done
done
done, i think
need more info
unbolt motor mounts
will do after trans unbolted
first things first
thats the plan ^_^
Old Mar 8, 2005 | 01:09 PM
Siegel1719's Avatar
Car: 85 Iroc
Engine: 461
well i cant think of the exact # off hand for a SBC but there should be about 7 bolts around the outside of the trans bellhousing. The go in from the transmission and screw into the engine block. there kinda hard to see but not to bad.
Old Mar 8, 2005 | 01:11 PM
Scotty562's Avatar
Car: 2001 SS Camaro
I failed to mention it is an automatic transmission. Do I have to remove the converter to see the bolts you are talking about?
Old Mar 8, 2005 | 01:12 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
sounds to me you have a few more bolts between trans and engine.
I have 6 holding trans to engine.
I have 3 holding converter to flexplate(v8 may have more)
May want to atleast loosen the trans crossmember bolts, cause you need engine to come forward to come away from trans. But engine wont go forward tell after it clears motor mounts, which need to come up.
If you have a 700r4, their may be a bracket system running along right side of oil pan holding the lines that go to the radiator.
Edit, yes you need to remove that bottom dust cover to gain access to tq bolts.
Also support the front of the trans some how, cause when engine/trans seperate, its just going to flop down, breaking and/or bending something.
Old Mar 8, 2005 | 01:19 PM
Lason's Avatar
Yeah and GOOD LUCK getting the motor back in with the tranny sitting there. Its usually easier just to yank the tranny out with the motor and then split them on the ground.
Old Mar 8, 2005 | 01:24 PM
Scotty562's Avatar
Car: 2001 SS Camaro
will it be easier just to yank them both out at the same time?
like i said, i'm a first timer just trying to figure out the easiest way to do this.
Old Mar 8, 2005 | 03:01 PM
Dale's Avatar
Engine: 350 S-TPI
I pulled my v6 with the trans in the car. Coming out wasnt to bad. Going back in I did have a bit of problems. But 3 people managed to do it.
I couldnt see an easy way pulling all together since the car is unibody and front core-support cant be removed like my s10 was. I know it can/has been done, but I didnt.
Old Mar 8, 2005 | 06:44 PM
rsn932's Avatar
I think it's easier to pull the tranny with the engine (although I've never done them separately). When I was doing mine at school, my shop teacher wouldn't even let me think about leaving the tranny in. He has had many frusterating experiences trying to get them back together with the tranny still in the car.
Old Mar 8, 2005 | 11:30 PM
flyitlikustolit's Avatar
Car: 1982 Trans Am
Engine: 383 chevy
Axle/Gears: 4th gen 10-bolt, posi, 3.42 ratio
yet another vote for yanking them together.... this is still a commodious enough engine bay to pul both together. you have 6 bolts holding your tranny onto the motor..... put the bottom 2 back in.
next, unbolt the tranny from the x-member, and the x-member from the car. (make sure the tailshaft is supported).
remove the distributor cap and rotor.
unbolt the motor mounts.
start lifting up, the just before you touch the firewall, pull the hoist towards you. up some more. keep doing this until you clear the mounts. then, up, up, and away, all the while point the tranny down, until you clear the core support. (yuou may have to inch the hoist back farther and farther to help gie room as you hoist the motor up.)
any questions, let us know. this can be done easily, and you'l find it's much easier to do it while it's all together. TRUST me.
Old Mar 9, 2005 | 11:30 AM
Scotty562's Avatar
Car: 2001 SS Camaro
Thanks for the info guys, i'll let you know how it turns out.
Vintageracer
Jan 10, 2020 05:33 PM
Infested
May 22, 2018 11:56 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
