Ford 9" factory spline count
Engine: 383 carbed sb
Transmission: th350
Hey guys. I am seriously considering buying a Moser housing w/axels and building a 9".
Does anyone know what most factory FORD axle spline count was?
What would most guys recommend for a spline count?
Car: 4
Engine: 6
Transmission: 5
i found 28,31, 35 at strange. easier to ask than search.
http://www.gearsareus.com/GearsAreUs...f/posiford.htm
Transmission: th350
In any case, I just ordered a moser 9" housing with axles for my '88 setup for lt1 brakes and 31 spline. I am gonna run a auburn posi with 4.30 gears.
The car was a T5, but is now a th350. I have a t56 out of my wrecked LT1 that needed some work, and when its done, its going in there. I figure for this season gonna race it with the trubo 350.
Thanks for all your help!
P.S. I wonder if I could get a centersection with gears (open diff) from a local boneyard and get a powertrax locker with 31 splines and install that and make work to start??? Anyone know?
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
yup, then 31 spline looks like what you're after.... any decient truck 9" would have 31 splines... they're fairly common, and aftermarket/OEM parts for it are plentiful....
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Ford produced 28 and 31 spline axles for their 9" diffs. I use aftermarket 31 spline axles just because parts are easier and cheaper to find for 31 spline than for 35 spline. I may be getting close to the limits of 31 spline axles but until I break one I'll keep using them. 35+ spline axles start adding weight that I don't need. Gun drilled axles can cut the weight down but are also at a much higher cost.
Car: 87 IROC L98
