10 bolts from fourth gen
Old Apr 5, 2005 | 10:15 PM
KnightWarrior's Avatar
Car: 1985 Camaro Z-28
Engine: 305 V-8 4BBL (H) Supercharged
Axle/Gears: 3.42 Eaton Posi
Will a posi, rear disc-equipped 10bolt third member from a 97 firebird fit an '85 Camaro?
Old Apr 5, 2005 | 11:00 PM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
I know the answer if you explain what a 3rd member is. Factory names of parts are best, everybody knows what you are talking about then.
Kinda like tappets and lifters I suppose.
Old Apr 6, 2005 | 12:14 AM
The rearend assembly, differential, axles and rear disc brakes
Old Apr 6, 2005 | 12:39 AM
Engine: SBC, LS-x
To the best of my knowledge the carrier will fit. The axles will be too long for your brakes to mate up properly.
You can use 4th gen axles in 4th gen housings. 3rd gen in 3rd gen housings.
The whole rear end will bolt up pefertly and carry over the brakes from one eara to the other. All cause of the axle tube lenght/brake mounting flanges...
Terrell351
Jun 13, 2021 01:13 PM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
