t56 torqe arm
Car: 1983 Camaro SC, 1991 Camaro RS Vert
Engine: 350 Crate, LO3
Transmission: T-56, 700R4
t56 torqe arm
hey guys I tried searching but couldnt find anything and i need an answer soon. In the next few days I will be swapping my 700r4 for a t56. the t56 i have came out of a 95 z28, and i need to know if the stock torqe arm from an 83 will fit. Thanks
So did see a big improvement with the spohn?
Car: 4
Engine: 6
Transmission: 5
No, not really; but that's because I already had one just about like it with my T-5.
That one, I did notice a significant improvement. It was like taking a giant rubber band out of the drive line somewhere.
91Z28-350 so i can reuse the stock torqe arm from a 83? At first I thought I could but I was reading the t56 swap in the FAQs and it said that 82-83's were different. so im really confused.
Car: `86 SS / `87 SS
If a tq. arm from an 83 were used from a T5 car, it would be the right length for a 95 T56/bell, but I don't know if the front would be the "W" shape and compatible with the T56 bushing, or if it would be he "M" shape and compatible with the T56 bushing. I don't have to deal with that crap on my car.
A friend just put an Addco tq. arm on his 98 T/A yesterday. Seems like a solid piece. Uses their own bushing which fits the stock bushing sleeve. :shrug:
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
You can take that whole mount off the t-5 and swap it with the t-56 one and not have to deal W or M thing if you find it dont match up. I'am using the one off my t-5 to since my tranny never came with one.
I cant use a t5 mount beacause im swapping from an auto but thanks for the ideas.
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
The other thing that you can do is get the correct bushing from Energy Suspension, it will fit in the T-56 mount. The T-5 mount and the T-56 mount are indeed the same, but there is no way to make the 700-R4 one work. Trust me, already done it. While you have the opld tranny out, spend the money and replace the rear main seal, I didn't and now I get to take mine back out to do it. Also, make DAMN SURE that the clutch fork pivot bolt is tight, mine backed out a little and I ended up with the fork and the pressure plate meeting at 3000 RPM, not a good place for that meeting.
bigjay89gta
Oct 15, 2015 08:04 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
