12 bolt in a thirdgen
Old Jun 15, 2005 | 11:00 PM
hotrod87camaro's Avatar
Car: 1987 Camaro Sport Coupe LT
Engine: 357
Transmission: turbo 350
Axle/Gears: 10 bolt posi, 3.73 gears
how much trouble is it to put a 12 bolt rearend in a thirdgen? i know someone that has one i could probably get cheaper than buying a posi unit and gears. has anyone here done this? what all would be involved?
Old Jun 15, 2005 | 11:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Since the third gen never came with a 12 bolt, there are no factory 12 bolts that are a direct bolt in. Because of the third gen torque arm suspension, swapping in a junkyard 12 bolt isn't very easy since there's no strong way of attaching a torque arm mount to the cast iron center section of the 12 bolt. The only factory 12 bolt narrow enough to fit under a third gen is from a first gen.
A complete aftermarket direct bolt in 12 bolt for a third gen is around $2500
Old Jun 15, 2005 | 11:56 PM
Engine: 357
i didn't expect it to be a direct bolt in, i was just wondering if it was even possible and what all i would have to do. i think the rearend is actually from a 69 Camaro. would there be any way to attach a torque arm to it? basically, can i make it work or would i be better off to just get gears and a posi for my stock 10 bolt?
Old Jun 16, 2005 | 12:04 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Using the factory suspension system, converting the diff could cost you more than the cost of a new diff.
As I already mentioned, the 12 bolt center section is cast iron. To fabricate a mount so that the torque arm could attach to it, you need to do some engineering for proper position plus you'll need to weld the mount or mounting plates onto the cast iron housing. The proper way to get a good weld on cast iron is to heat it up with a torch until it gets red hot before welding to it. Although this isn't a problem for any welder, the problem you'll probably get after any kind of welding onto the housing is warping. If the pinion bearings or side bearings go out of alignment, I don't think there's any way to fix it.
Personally, I'd stay away from trying to adapt a factory 12 bolt to a third gen unless you plan on changing the rear suspension to ladder bars or a 4 link system. It's a lot easier to adapt a 9".
Old Jun 21, 2005 | 12:38 AM
Engine: 357
somebody told me they thought there was a kit or something? kind of like the torque arm relocation kit for a turbo 350. has anyone ever heard of this before?? i could probably get it a lot cheaper than buying a posi unit for mine, and i'm sure it would be a big upgrade from my current 10 bolt so i was just hoping there was a way to do it.
Old Jun 21, 2005 | 07:42 AM
AlkyIROC's Avatar
Car: 87 IROC L98
The torque arm relocation bracket is for a transmission swap not a diff swap.
Old Jun 21, 2005 | 09:40 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
You are probably thinking of the south side machine ladder bar set-up which replaces the torque arm, it is sold as a 'kit'. Check summit racing.
Old Jun 21, 2005 | 10:36 PM
Engine: 357
i know that, i'm not retarded, i was thinking they might make a bracket for that too, like a similar ideal but for the rearend rather than the transmission. i know its different.
Old Jun 21, 2005 | 11:13 PM
AlkyIROC's Avatar
Car: 87 IROC L98
You can buy a torque arm mounting bracket for a 9" from Currie but nobody want's to risk selling something like that for a 12 bolt because it would need to be welded to cast iron. A bolt in 12 bolt has a mounting area cast into the housing.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Terrell351
Jun 13, 2021 01:13 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
