Name that Lever!!!
Old Jun 22, 2005 | 08:23 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Name that Lever!!!
Im doing a shift kit and i think i broke this lever. Can you tell me what it is PLZ
Old Jun 22, 2005 | 08:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You've got the shifter cable circled there. The lever it attaches to could go by several names. Shift lever? Manual shaft lever? Selector lever?
Old Jun 23, 2005 | 12:46 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Thanks alot bro. Im going to have to buy a new one. Have you ever installed one before? Does it run to the shifter ***?
Old Jun 23, 2005 | 01:01 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It's pretty easy to replace. The cable runs from the bracket on the transmission through a grommet in the floor to the shifter. It might take a few tries to get it adjusted properly, but it's not that big of a deal.
Old Jun 23, 2005 | 01:09 AM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
how do you adjust it?
Old Jun 23, 2005 | 01:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you have the the shifter and the transmission in neutral whene you tighten the nut that attaches the cable to the slotted lever it should be properly adjusted, but sometimes things like to move when you tighten the nut so it might take a couple of tries.
Old Jun 23, 2005 | 08:34 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
ding ding ding....BOB, I am going to go with a "shift cable!"
wigmobile
Feb 26, 2025 02:56 PM
ndndndnd
Sep 28, 2015 08:00 AM
tattmann
Sep 27, 2015 05:20 PM
Todd84Z
Sep 4, 2015 08:02 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
