cant adjust backlash
Old Jun 28, 2005 | 06:33 PM
camarokev400's Avatar
Im trying to install a posi out of a 89gta into my 86 z28, Im not real sure what is going on but i have way too much backlash, so much that shims arent going to fix it. Here is what i did and this is prob my mistake but i want to know for sure, i left my pinion gear that was origianlly in the car in place and took the ring gear off my old open rearend, which was in the car and put it onto the new posi. I am guessing the ring gear that was in my car isnt made for this carrier even though it bolted right up? help me out guys, a ring gear came on the posi when i bought it and ive tried putting that ring gear in with my pinion and its the same thing... way too much backlash. I think i might have to get a new ring and pinion made for this carrier, am i right?
Old Jun 29, 2005 | 05:10 AM
ede's Avatar
ede
how can shims not fix it? you don't increase the total shim thickness, you only change the arrangement from side to side to increase the shim thickness on one side and decrease it on the other
Old Jun 29, 2005 | 06:27 AM
ive tried putting bigger ones on the drivers side and smaller ones on the pass side, the thickness is still the same as the original ones howeverit still isnt tight enough
Old Jun 29, 2005 | 06:48 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I have a feeling that the two carriers are different series. To check place both carriers upright on a bench with the passenger side bearing up (the ring gear teeth would also be up).
Look at the flange the ring gear bolts to, both carriers need to have that flange at the same height. If not then they are two different series carriers. The two would be 3.23 and up, and 3.08(?) and down (such as 2.73).
RBob.
Old Jun 29, 2005 | 08:21 AM
ede's Avatar
ede
didn't think about the carriers series not matching the gear set. you might need a shim for the ring gear.
Old Jun 29, 2005 | 11:33 AM
thanks guys, i will check that out tonight, if that is the case where would i get a ring gear shim? and how do i know how thick it should be?
Old Jun 29, 2005 | 03:00 PM
TexasLT1's Avatar
Car: '92 RS
I believe its .25" difference between a 2 and 3 series carrier.
Old Jun 30, 2005 | 10:29 AM
Chris89GTA's Avatar
Car: 1989 Trans Am
Engine: 355 HSR
Transmission: Pro-Built 700r4 w/ 3400 converter
Axle/Gears: 10 bolt w/ 3.42 gears
What gears did you take the ring gear from to install w/ the existing pinion? Are they the same?
InfernalVortex
Apr 20, 2021 11:31 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
