How fast am I going?
Old Jul 11, 2005 | 03:06 PM
91 VANE Z's Avatar
Car: 91 Z28 Convertible
Hello. I'm new to the Camaro world and have a question.
My speedo was telling me that i was moving about 90 miles/hour
but judging by the minivans flying by me I think I was doing maybe 75. I've heard if one were to play around with the gears in the rear end that it will throw the speedo out.
Is this true? I never know how fast I'm going. I drive a deep purple convertible, I see cops always runnin my plate, a few actually made a u-turn to follow me and check it out.
I don't want to get caught speeding doing 15 over on some bloody residential street.
thank you in advance
Old Jul 11, 2005 | 08:52 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Mine under read by 25% when I got it. I pulled the diff cover to check the gears were what they were supposed to be, then checked the speedo gears to check that they were what they were supposed to be. One of the speedo gears was wrong. Previous owner must have changed it over and not bothered to swap out the speedo gears. An easy fix.
Old Jul 11, 2005 | 08:57 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what he said (change the diff fluid) (then check the gears in the trans tail shaft) both jobs I think anyone who changes there own oil can more than handle
Old Jul 11, 2005 | 11:18 PM
91 VANE Z's Avatar
alright, sounds easy enough, How can you tel what gears are in there? I did a search here and came up with counting teeth but didn't find find out how many teeth to look for, for the range of gears available.
Thank you
Old Jul 12, 2005 | 07:48 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
I'll use mine as an example. Count the ring teeth. Mine came up with 41. The count the pinion teeth, which for me was 15. Divide 41 by 15 which gives you 2.73. Easy. Or, the ratio should be stamped on the gears somewhere.
Old Jul 12, 2005 | 09:59 AM
Difflock's Avatar
Car: VIN=85 T/A, CAR=82/3 T/A gfx, go figure. She's a T/A anyway!
Engine: 5.0, Holley 600 cfm 4-barrel
Transmission: THM350 ??
Different tyre sizes can slightly contribute to the effect if the rolling radius (wheel/tyre combo) has changed.
InfernalVortex
Apr 20, 2021 11:31 AM
grngryoutmyway
Oct 18, 2016 05:48 PM
sreZ28
Oct 22, 2015 08:21 AM
Nervous2
Oct 8, 2015 10:53 PM
customblackbird
Oct 1, 2015 04:30 PM
