Pro 5.0 shifter question
Old Jul 21, 2005 | 05:06 PM
cwalsh's Avatar
Car: 2004 Corvette
I was searching through the boards about this shifter and was wanting to know if it fits OK in a 3rd gen Camaro console w/ a T56 & a Lou's short stick? Or is there a need for the short stick in the 3rd gen console. Also I have a Mallory shift **** which screws down farther so I am not sure of the need for the short stick. Any input would be great.
TIA
Chris
Old Jul 21, 2005 | 05:55 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Sicne you have a T56 you can run the 4th gen Pro 5.0 tailored for that tranny. Before you buy the short stick I would install the shifter and see if you like the height. It is held on with two cap screws and can be removed in seconds. You can cut the shaft down as well if you want it shorter. The short stick is cool but it is just to easy to modify the shaft that it comes with.
Old Jul 21, 2005 | 10:41 PM
cwalsh's Avatar
Car: 2004 Corvette
Kind of what I was thinking of doing.
Thanks!
Old Jul 21, 2005 | 11:21 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Not sure how short the "short stick" really is, but I cut my Pro5.0 down about 1", and I had an MBA **** which they say are threaded deeper to screw on further, in effect acting like a shorter shift stick. I know it was pretty low, much lower and i'd be digging in the console to find my shift ****
I'd definetly try it as-is first
Old Jul 24, 2005 | 06:04 PM
cuda69's Avatar
Car: 91z28vert,3:42posi-rear,gu6
Engine: 305TPI
Transmission: T-5,pro5.0 shifter
i just put in a pro5.0 in my 91 z28 console and its about an inch to long for stock outer boot but i left it alone i have gotten used to it,and now love the shorter throws its a great alternative to my stock piece ,that dont even compare,i would reccomend this shifter all the way
Old Jul 25, 2005 | 09:54 PM
jcurrieirocz's Avatar
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
yep its awsome how better it feels to drive with a shorter throw and stiffer shifts!!
I didnt cut mine down as i like it the way it is... and im scared i may go too short. I wish i could make one to cut up to try.
Old Jul 26, 2005 | 03:35 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
The Lou's short stick fits fine in my T/A, not sure if that helps or not.
Old Jul 26, 2005 | 07:38 AM
cwalsh's Avatar
Car: 2004 Corvette
Thanks everyone for your opinions. I will ditch the B&M and get a Pro 5.0.
Chris
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
ron reece
Southern California Area
Oct 7, 2015 01:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
