TV cable change
Old Aug 3, 2005 | 02:46 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
TV cable change
What is involved with changing the TV cable? Pan have to be droped?
Old Aug 4, 2005 | 05:44 AM
BRobinson's Avatar
Car: 82 Camaro
Transmission: TH-350
Axle/Gears: 3.08
Drop the pan, and on the pass. side, there will be a little metal rod between the end of the cable and a metal arm. It will kinda look like the accelerator pump on a carb. Loosen the bolt on the clamp holding the TV cable. Take the rod off. Switch the cable, then put it back in the tranny. Tighten down the clamp, Reattach rod. Close up the tranny and re-attach to engine. Enjoy.
Old Aug 4, 2005 | 09:31 AM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
You don't have to drop the pan to change a TV cable, atleast not on a 700R4. Just undo the one bolt holding the cable to the transmission then lift up cable and unhook it from the transmission and put the new one on.
Old Aug 5, 2005 | 08:00 AM
Car: 1971 Camaro
Engine: 427
2 totally different answers, anyone else?
Old Aug 6, 2005 | 02:43 AM
MdFormula350's Avatar
well the first dude has a th350 and second dude has a 700r4.
Old Aug 6, 2005 | 01:53 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
It can be done without dropping the pan.
Old Aug 16, 2005 | 03:28 PM
Car: 1971 Camaro
Engine: 427
Okay, got it changed out. What a PITA! Due to my dsl, I had to unbolt the torque arm and ds to get the tranny to drop enough,
I have a problem though. The old cable had a sleeve at the end, after the hook up for the TB, the new one did not, making it too long. Well, I made up a sleeve for it to get it the same length, but I can not get the thing to adjust.
I have tried it several times following the instructions on this site, but when I move the throttle to wide open, I do not hear any 'clicks" of course, when I tried to drive the car, it would rev real high before shifting.
What is going on here? AM I missing something?
Old Aug 16, 2005 | 05:10 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It almost sounds like you haven't got the right replacement cable.
Old Aug 17, 2005 | 08:11 AM
Car: 1971 Camaro
Engine: 427
MAn, I sure hope not. It was a pita. It looks the same as the old one with the exception of the sleeve on the end of the cable.
Old Aug 17, 2005 | 10:34 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
All the lengths are the same?
Old Aug 17, 2005 | 10:47 AM
Car: 1971 Camaro
Engine: 427
They were the same length, only difference was the sleeve, which I mentioned earlier.
Old Aug 17, 2005 | 11:27 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Not just the overall length, but the same amount of cable past the adjuster, same range of travel on the adjuster, etc.
Old Aug 17, 2005 | 11:31 AM
Car: 1971 Camaro
Engine: 427
Well, thats tough to say, but It appears to be about the same. Even with the old one, after getting the car back together with the stealth ram on, I could not get it to click.
Old Aug 17, 2005 | 11:47 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Well in that case then, you've got a TV geometry problem.
Old Aug 17, 2005 | 12:21 PM
Car: 1971 Camaro
Engine: 427
Please explain.
Old Aug 17, 2005 | 12:23 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
At the very least, your bracket isn't mounted far enough back from the throttle arm.
Frozer!!!
Jan 19, 2024 04:55 PM
9192camaro
16
Feb 3, 2019 12:21 AM
deracer
Apr 11, 2016 12:04 AM
Spd-Kilz
Interior Parts Wanted
Aug 15, 2015 12:12 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
