Holy Jebus Will This Fit?!?!
Old Aug 4, 2005 | 07:27 PM
83_Camaro_83's Avatar
Car: 1987 Z28
Engine: Tree Fiddy (modded)
WILL A C6 TRANNY WORK/FIT/HOLD UP IN MY CAR??!?
Heres the ad:
C6 rebuilt tranny, red racing clutches, stg 2 shift kit, 3500 stall, never used, 1300inv, first 600 takes
Is this a 6 speed corvette tranny? if it fits and stuff Im so gonna get it.
obviously it will hold the power of a 383 right?
im excited now
Old Aug 4, 2005 | 07:36 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Uh, i think its a ford C6 trans....
Old Aug 4, 2005 | 07:37 PM
Car: 1987 Z28
Old Aug 4, 2005 | 09:18 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
arnt the corvette c6 trannys on the rear axle?
Old Aug 5, 2005 | 01:45 AM
KagA152's Avatar
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
i would assume it is a ford c6, so no, it wont work
and afaik c6 corvettes use a transaxle setup just like the c5s
Old Aug 5, 2005 | 11:16 AM
formula350sd's Avatar
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
Im pretty sure there would be a way to adapt the transmission and it should take the abuse but the question is why in the world would you want to
Old Aug 5, 2005 | 02:04 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
There are no adapters to bolt a ford tranny to a 2.8.
Oh, and its an auto, not a 6 speed. The stallconverter and shift kit should have made that obvious.
C6 trannys are part of the rear axle, trans axle, like the old VW's
Old Aug 5, 2005 | 02:28 PM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
Yup, a C6 is a Ford trans. Same basic idea as a TH400. It was Fords heavy duty trans used behind FE big blocks and in trucks. Typically anything with a 351W and up got a C6.
Corvettes, both the C5 and C6, use a version of the T56 6-speed. It is incorporated into the rear axel assembly to make a transaxel that is mounted in the rear. That trans is no usable in anything but a Corvette. People that swap a T56 into a 3rd gen are either using the 4th gen LT1 T56 or an aftermarket retrofit T56 made for swaps into other vehicles.
Earlier Vettes used a ZF 6-speed or the 4+3, which was basically a Super T-10 with a grafted on overdrive assembly that could split gears. They were not known for their reliability.
I'd let the C6 go. It isn't what you need. If you want a stout automatic look for a well built 700R4 or TH350. If it's a stick you're after a T56 is a good option, as is a well built T5.
Old Aug 6, 2005 | 02:05 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Wasnt there a builder here awhile back that retrofitted them into GM cars?
Old Aug 6, 2005 | 02:17 AM
Car: 89 Formula
I don't wanna be an *** but re read his post he is talking about putting it behind the 383 he is building for the car not a 2.8
And i know there are people that adapt ford transmissions to gm I ahve heard of aods behind small blocks
Old Aug 6, 2005 | 12:06 PM
There may be adapters, but if you are starting off buying up stuff from scratch just buy a GM trans. It will make your life so much easier. A C6 isn't any stronger than a TH400, so there really isn't anything to gain.
Fronzizzle
Feb 9, 2017 09:31 AM
New2Chevy
Sep 28, 2015 12:35 AM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
BOOT77
Sep 5, 2015 03:55 PM
Formula_88AE
Sep 3, 2015 01:47 PM
