Ring and pinion question
Old Aug 23, 2005 | 07:26 PM
demetri's Avatar
Im trying to find ring and pinion sets for a 91 Rs and I keep seeing 7.5 27 splines . Is mine a 7.625 or a 7.5 and mine is 28 and not 27 spline right?
Old Aug 23, 2005 | 11:46 PM
phoenix305's Avatar
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
It doesn't matter as long as you are not replacing the carrier, our rears are 7 5/8 or 7.625. But usally the gears say they are made for 7.5 AND 7.625. Should bolt right up if you get them for the right series carrier and know how to set up a rear end.
Old Aug 24, 2005 | 12:51 AM
Jade Grey's Avatar
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Demetri, you're still asking this same question?
GM changed from a 7.5" ring to a 7.625" ring sometime in the mid-eighties. As Phoenix305 said, either will fit your carrier. Just get an aftermarket set like Richmond, http://www.jegs.com/cgi-bin/ncommerc...61&prmenbr=361. If you are staying with your stock carrier, you will need a 2-series (thick) version.
Your '90 RS has 28 spline axles as GM changed over mid-year 1989. The 27 spline count you mentioned is the gear pinion's spline count.
HTH
Old Aug 24, 2005 | 05:46 AM
demetri's Avatar
So thats what I look for? 27 spline pinion? 200$ is a little pricey but I guess these are the best right?
Old Aug 24, 2005 | 06:31 AM
ede's Avatar
ede
you won't have a choice on pinion spline for a 10 bolt. i don't think you have a very good handle on what spline is what, 28 or 26 is the axles, the pinion never changed. not sure but i'd just about bet the 9 bolt used same splines so the yoke interchanges.
Old Aug 24, 2005 | 02:02 PM
demetri's Avatar
All I need to know is what to look for.
Old Aug 24, 2005 | 08:04 PM
phoenix305's Avatar
Here, plain and simple get what ever gear ratio you need, but make sure its for a series 2 carrier and a 7.5 and 7.625 rear. I wouldn't go with richmond gears unless your planning on using them for drag race only. They can handel alot but they whine more than other brands. I went with motive gears.
Old Aug 25, 2005 | 05:48 AM
demetri's Avatar
why not 3 series
Old Aug 25, 2005 | 08:49 AM
HalfInchWrench's Avatar
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
Because you have a 2 series carrier. You need the thicker ring gear. 3:23 gears and up from factory use a 3 series carrier. In case you don't know, the carrier is the differential.
Old Aug 25, 2005 | 01:51 PM
demetri's Avatar
the posi that im buying comes with a differential doesnt it?
EDIT: Actually why don't you just tell me what to buy. (no aubern)i just want a posi with a 3.42 gear (or tell me if i should go higher)
Old Aug 25, 2005 | 02:02 PM
ede's Avatar
ede
a posi is a differential
you need:
a carrier also called a differential, or posi (if it's a posi)
a gear set in the ratio of your choice, it'll also have to fit the carrier, either by being the correct part or by being a part made to adapt nonstandard ratios to carriers they didn't come from the factory with, or by using a ring gear shim.
a modified cross pin if you go 4:56 and maybe another ratio or two, but i tihnk it's 4:56 only
an install kit
oil
posi additive, gm only
someone to install it for you
Old Aug 25, 2005 | 02:31 PM
demetri's Avatar
so this
https://www.justdifferentials.com/st...cat=172&page=1
and this
https://www.justdifferentials.com/st...cat=381&page=1
and this
http://www.jegs.com/cgi-bin/ncommerc...17&prmenbr=361
and this
http://www.jegs.com/cgi-bin/ncommerc...19&prmenbr=361
and this
http://www.jegs.com/cgi-bin/ncommerc...48&prmenbr=361
That will all work right?
Old Aug 26, 2005 | 10:32 AM
demetri's Avatar
bump..
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
Mickeyruder
Sep 2, 2015 02:45 PM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
