Axle swap question
Car: 87 TA
Axle swap question
I just bought a rear from (I think) an 87 Camaro. It was out of the car when I got it. It's a 4HJ code, 3.42 posi. I think it started life as a 3.23 and had a gear swap. Gears look good, but it has a bad axle, 26 spline. The bearing surface is galled, rough, and no longer smooth. I'll change the bearings.
Here's the question. Will an axle out of my 2.73 peg leg rear work in the posi? If not, I'll have to buy a new axle.
Thanks for the help.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All the third gen 26 spline, 10 bolt axles will interchange. They're even the same length on each side.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Another option, perhaps, is an off-set bearing, which allows the original axel to ride in another spot on the bearing.
JamesC
JamesC
I once heard an old mechanic say that he simply used the tip of the axel to pry the bearing out. I'd prefer the slide hammer, I think.
JamesC
JamesC
