What speedo drive gear comes in 1989 WC T5 (305 tbi)
Old Sep 26, 2005 | 07:11 PM
327_TPI_77_Maro's Avatar
Car: 2000 BMW M5
Hi guys, I have the WC T5 behind my 327 now. Everything is great except now my speedo is off -- I had it perfectly calibrated with the muncie 4 spd, but the muncie's speedo drive gear (on the output shaft) did not fit the WC T5 output shaft so I had to keep the stock gear in the T5. With a 19 tooth driven gear the speedo reads way too fast -- I grabbed a 22 tooth driven gear at the junkyard today and I'll see how that does. However I'd like to calculate what driven gear I actually need -- what drive gear will this 1989 Camaro 305 tbi WC T5 have in it?
Old Nov 8, 2005 | 01:47 AM
laegion's Avatar
Car: 84 Trans Am Ws6
Engine: 305 LG4 "H.O."
Transmission: wc t-5
that is a good question I am also trying to figure out that same question.
Anyone out there know?
Old Nov 9, 2005 | 09:19 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Either a 7 tooth or a 9 tooth.
Old Nov 9, 2005 | 10:15 PM
88IROCARMY's Avatar
http://www.transmissioncenter.net/sp...n_______va.htm
try bottom of page for speedo calibration
Old Nov 9, 2005 | 10:48 PM
laegion's Avatar
just because that program says what should be in there doesn't mean that is what gm used. I'm not going to go out and buy a driven gear if I don't know for sure it's the right one.
Old Nov 10, 2005 | 12:08 AM
jmd's Avatar
jmd
Their selection of gears for the 700-R is just flat out wrong for the given combinations against what GM used in cars with a 26" tire.
Old Nov 10, 2005 | 12:12 AM
laegion's Avatar
not to mention we're both using t-5's
Old Nov 10, 2005 | 12:14 AM
jmd's Avatar
jmd
The calculator is wrong for T-5 combinations too.
I gave up on "online gear calculators" a long time ago so I didn't bother reading the whole page. All the calculators are wrong, thus far.
Old Nov 12, 2005 | 10:28 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
TBI's with 5-speeds all had 3.08 gears as far as I know, which is a 9 tooth red drive gear and a 22 (or 23 tooth) driven gear. Sorry I cant remember if its 22 or 23 nor what color the driven gear is...
InfernalVortex
Apr 20, 2021 11:31 AM
FormulaEngland
European Region
38
Jul 17, 2016 07:33 AM
loud91rs
Oct 5, 2015 10:05 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Bigold4x4
Sep 28, 2015 05:21 PM
