Shift Kit Question
Old Oct 3, 2005 | 09:32 PM
z28 NyC's Avatar
Car: 1986 Camaro z28
Engine: 305 tpi/light mods
Transmission: 700r4/ B&M mega shifter
Shift Kit Question
I have a B&M mega shifter kit , Bought my car a while ago it came with the shifter, the shifter handle looked pretty worn out plus sometimes the trans slips pretty bad when Iam going hard just wondering if you should change ur trans oil more often if ur running a kit, and also I know B&M makes their own trans fluid anybody know if its worth it.
Old Oct 3, 2005 | 10:08 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
the b&m mega shifter has nothing to do with a shift kit. it is just a means of shifting the transmission. you could try a fluid and filter change but you should probably adjust the tv cable first. if it is not adjusted properly, it will cause slippage.
Old Oct 3, 2005 | 10:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
The B&M fluid isn't worth it. If you think you really need a "performance" transmission fluid (you don't), then regular Ford Type-F fluid is the same as the B&M fluid, just without the fancy blue dye.
Old Oct 4, 2005 | 06:28 PM
z28 NyC's Avatar
Cool guys, thanx
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
italiano67
Dec 11, 2016 09:21 AM
crazynights
Aug 21, 2015 06:53 AM
TreDeClaw
Aug 14, 2015 06:58 PM
dhonda200
Aug 11, 2015 11:50 PM
