interchangable axles
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
I have a 9 bolt that recently went bad. Upon dissassembly I found that the axles were worn down. The 9 bolts came with 28 spline axles, as did the 90+ 10 bolts. I am wanting to know if the two sets of axles are interchangable?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You might as well ask if a Ford 9" 28 spline axle will fit.
10 bolt and 9 bolt diffs are completely different. Nothing internally is interchangable. The only replacement for a 9 bolt axle is from another 9 bolt.
[ON] 9 Bolt Axles Partout
6speedIROC
16
Mar 15, 2023 08:33 PM
rudolphschenker
Sep 4, 2015 02:41 AM
