700 r4 shift kit
Old Nov 10, 2005 | 10:59 PM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
700 r4 shift kit
i put a stage 2 b&m shift kit in my 700r4 and was told i can shift manually with the car without hurting the trans is this true?
Old Nov 10, 2005 | 11:04 PM
84z28350's Avatar
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
Manual shifting wont hurt it AFAIK. Its actually supposed to be better as it increases line pressure, reducing slip.
Old Nov 10, 2005 | 11:13 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
well when mine was stock, i used to shift it manually cuz it short shifted somewhat
and plus it was fun...
one day i blew it up while i was racing. shifted second into 3rd, and it wouldnt go into third and i took 2nd to 5500rpms and let off the gas .. it then went into third. after that, i lost od and third. LOL
since then, i got a rebuild and shift kit. and shift it manually at the track and it runs great. shift kit is nice. but i'm not sure if thats good for it or not. i always heard its not the best thing to do, and thats why they make manual valve bodies for that stuff. so far, my tranny has like a abit over a year on it and 6-7K miles and it hasnt missed a beat.
Old Nov 10, 2005 | 11:16 PM
n8sz28's Avatar
Car: 85 camaro z28
does anyone know which aftermarket shifter is the best to buy for manually shifting. like b&m or hurst
Old Nov 10, 2005 | 11:17 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
a ratchet shifter would be sweet... my stock one is working just fine tho too
Old Nov 11, 2005 | 12:13 AM
n8sz28's Avatar
Car: 85 camaro z28
i m looking at a b&m console megashifter which is the ratchet shifter, but what exactly does it do?
does it give you complete control over the car like a manual and do have to pull it back for each shift or is it like a normal shifter where you put it in 1st gear than 2nd and on?
Old Nov 11, 2005 | 12:15 AM
Pro Built Automatics's Avatar
It takes more than the B&M valve body kit.
Old Nov 11, 2005 | 12:30 AM
n8sz28's Avatar
Car: 85 camaro z28
with the megashifter do always have to shift yourself or does it do it for you if you want it to. How does it work?
Old Nov 11, 2005 | 05:29 PM
Nate86's Avatar
Car: 1999 Saturn SL2
Engine: 4 cylinder
Transmission: 4-speed automatic
My friend had one in his old car. It basically shifts like a regular automatic in gear, but you can ratchet through each gear like in a manual (I think, don't quote me on this though).
Personally, if I wanted to shift through each gear individually, I would just put a manual in my car and skip the B&M shifter altogether.
Old Nov 12, 2005 | 09:52 PM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
the mega shifter works like a normal shifter when in drive or OD. it has a reverse lock-out so there is no way you can miss neutral and shift into reverse when manually shifting. it also has a detent assembly built into it so you will not likely miss a shift.
tonys91rs
Oct 10, 2015 03:31 PM
tonys91rs
Sep 2, 2015 07:07 PM
Mickeyruder
Sep 2, 2015 02:45 PM
Ducati900ss
Sep 2, 2015 09:05 AM
89 4Mula 350 Tbi
Oct 21, 2001 04:27 PM
