VSS in a 092 camaro
Car: 1986 Z28
Engine: 305ci
VSS in a 092 camaro
Where is the VSS (speed sensor) located?
I need to install a speedo calibration unit and I do not know where this sensore is. I need to tap into the wires for it so I need to locate this thing.
thanks
thanks
Car: 1986 Z28
Engine: 305ci
Originally posted by dankhound
Near the rear of the transmission.
Remove the center console.. is that an option?
Or do I need to crawl under the car?
Car: 91 RS
Engine: 305 Tbi (L03)
Just crawl under the car. Theres only two connectors on the trans. the one in the front is for the lockup converter and the one in the rear is for the vss.
Car: 1986 Z28
Engine: 305ci
Cool.. not sure when I will get that done. To bad there is no easy way for this one....
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Originally posted by 92need-a-z
The trick is to follow the wires to where they enter the car and then tap in to them for the speedo calibration unit.
Car: 1986 Z28
Engine: 305ci
Originally posted by Supervisor42
If it doesn't use a seperate VSS buffer, (like my 88) you could get your hands on a schematic and tap into them where they go into the ECM. Atleast the connections would stay dry.
any ideas on where to acquire that?
Car: 84 Z28
Engine: 357
Transmission: TH-350C
Axle/Gears: 3.43
haynes repair manual, or probably any repair manual should have the wiring diagrams.
Check around the tech articles here, theirs a few diagrams listed but i think their for the mid 80s
