V6 S10 or V8 Camaro torque converter?
Old Nov 19, 2005 | 05:11 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
I'm currently having my trans rebuilt for my 350 Bravada project. I'm wondering if I should reuse the stock Bravada torque converter or if I should put in the spare one I have from a Z28. I know the stock one will give me a higher stall speed but I've heard there are some durability issues with them (fins bending). The engine is roughly 350-400hp.
Old Nov 20, 2005 | 07:53 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
is the v-6 mentioned a 4.3 liter? if it is not, the input shaft is only 27 splines unless the tranny is being modified by installing the 30 spline input shaft. if it has the 27 spline input shaft, the z28 converter will not work because it has 30 splines. i don't remember which input shaft was used for the 4.3 liter motors.
Old Nov 20, 2005 | 03:33 PM
Car: '87 Camaro LT
Engine: 355 L98
It's a 4.3. I haven't verified yet but the splines should be the same.
Old Nov 20, 2005 | 04:34 PM
87zjeff's Avatar
ok, like i said, i'm not sure which splines the 4.3 liter came with. for some reason, there seems to be a general opinion on this board that the 27 spline wasn't made after '84 which isn't true. all v-6's smaller than 4.3 had 27 splines. the 4.3 i was unsure about.
Old Nov 20, 2005 | 04:51 PM
Jeffluke's Avatar
Car: 90 L98 IROC/87 LB9 NM5 1AZ / 96 TBI 350 700R4 XCAB S-10..LT1 SOON
Engine: L98/LB9/LT1
Transmission: 700R4/WC-T5
Axle/Gears: 3:73
ON MY 96 350TBI/OBD-2 TO OBD-1 X/CAB S10 I WENT WITH @ 1600 CONVERTER DUE TO THE ENGINE BEING STOCK W/89 FED HARNESS, IT WORKS PERFECT, BUT THEN AGAIN I HAVE 3:08S/2WDR. YOURS IS PROBABLY 3:42S, OR 3:73 (TOW PACKAGE) GOV LOCK, DEPENDING ON THE CAM PROFILE I WOULD BASE THE STALL ON THAT, AS YOU DONT WANT ALOT OF STALL ON A SMALL CAM, AND NEED IT ON A LARGER CAM.
Old Nov 20, 2005 | 04:59 PM
Car: '87 Camaro LT
Engine: 355 L98
It's 3.73 AWD. The cam is an LT4 HOT cam. 218/228 duration, .525 lift.
Old Nov 20, 2005 | 06:08 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
The 4.3L was not available until the 1989 model year, by that time all those 700's where 30 spline.
Old Nov 20, 2005 | 06:27 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
so with the factory S10 stall which is 2200 rpm. i've put them behind my 4.3L motor and was pushing low 11s in my truck on nitrous with no issues.
Old Nov 20, 2005 | 09:27 PM
87zjeff's Avatar
"The 4.3L was not available until the 1989 model year, by that time all those 700's where 30 spline"
not all 700's had 30 splines!!!!!!! only the v-8's and maybe the 4.3. other 6-cyl motors had the 27 spline input shaft up to at least '98
Old Nov 21, 2005 | 06:42 AM
Jeffluke's Avatar
Engine: L98/LB9/LT1
Axle/Gears: 3:73
BRAVADO/syclone
I always wanted to do a bravado v8 swap, or astro/ext as i could obtain 1 real easy having a lot of salvage connections, it sounds like a pretty radical swap w/lt1/lt4 , I believe that the vortec 4.3 trans is identical to the v8 w/the exception of the clutch pack count/govnr and servo, as for the (e) in 4l60, I am limited to playing w/700r4s ' w/valve bods, I rec that you contact dacco detroit or a trans shop to find out the dif between them is as you donot want to be pulling it right out again, the rest of the drivetrain w/3:73s is very capable (eventually ditch the gov/loc),and take some good v8 s10 advice: go w/the c4 vette radiator in the fwd position, it takes some cutting/relocating/mig welding/latch moving, but worth it, remember I went w/ac so I had to relocate the cond where the hood latch was, and then move the radiator into the support, and mount the latch around the cond, i use an 87 v6 fan shroud w/the v6 vortech fan and clutch w/the 96 s10 serp setup, as my truck is a 96 and doesnt have the lt1 accs, and looking at the JTR book, getting the ac comp to fit is some work, as is the lt1 manifolds, but not imposible, not for the timid or shy, good luck, if you have any questions just email me, jeff. .
Old Nov 21, 2005 | 10:32 AM
Ricktpi's Avatar
I believe the discussion here is about the 4.3L V-6. They have 30 spline input shafts the same as the mid 87 & up V8's
Old Nov 21, 2005 | 11:54 AM
87zjeff's Avatar
ok...your wording kinda threw me. i took it as you meant to say all 700's had 30 splines.
btw, the 30 spline 700 v-8 did start in mid '84.
Old Nov 21, 2005 | 03:26 PM
Jeffluke's Avatar
Engine: L98/LB9/LT1
Axle/Gears: 3:73
spline count
I just counted the splines on the converter that came out of my 96 vortec v6, 2wd, it is 30............. I guess the question is what year is the trans from the bravado? I agree the early 80' s700r on the v6 stuff was the smaller count spline, I am just not sure of the year they went w/30 splines on the v6, still I would go through the trans anyway, that should help somewhat.
Old Nov 21, 2005 | 04:19 PM
Car: '87 Camaro LT
Engine: 355 L98
It's a '92 trans.
Old Nov 21, 2005 | 06:23 PM
87zjeff's Avatar
if ricktpi is correct on the spline count for the 4.3, it is the only v-6 to have 30 splines. all other v-6's had 27 splines regardless of year.
Old Nov 22, 2005 | 05:23 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
Running a 95 S-10 converter behind my 383 with no issues.
Old Nov 22, 2005 | 08:29 PM
Jeffluke's Avatar
Engine: L98/LB9/LT1
Axle/Gears: 3:73
converter issue
Kinda reminds me of when friends of mine would go w/a vega t350 converter for the extra stall, that hot cam has a great profile,... build it right and upgrade the clutch packs and it will, ...maybe, last as long as you want it to, remember that trans is not a th400 or a4l80e.
Ukraine Train
Theoretical and Street Racing
Jan 23, 2002 06:11 PM
RARE-ROC-Z
Mar 5, 2001 01:06 AM
Daz
Jul 23, 2000 08:11 AM
