Definitive VSS answer
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
Is there a different T-5 VSS for 86-90, and one FOR 91 92. I have this sensor, PICTURED, but my 1989 plug is more like the plug for my auto VSS/reverse light plug.
Thanks to PAUL, from whom I copied the pic. Also any P/N's WOULD HELP.
shawn
shawn
Car: 1981 Camaro; 1986 Z28
Engine: LT1; LT1
Transmission: 6 speed; 6 speed
Axle/Gears: 3.73; 3.42
the only different vss sensor is used on the 4th gen and they were physically smaller and had a different plug on them.
Anyone one else????
Chime please, I don't want to spend 60 bucks if i don't need too.
What is the deal with the 4000 pulse, and 2000 pulse. Can I just scratch build a connector for this andhope it works. I am looking to try to drive the car this weekend.
thanks
thanks
Car: 1986 Z28
Engine: 305ci
Originally posted by irocnroll89
Anyone one else????
thanks
Anyone one else????
thanks
I used a Dakota Digital unit to fix the speedo in my car.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
'90-'92 4000 pulse, like the one in the picture.
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
The 2000 pulse sensors where optical units mounted to the back of cable speedometers. They switched to the magnetic 4000 pulse transmission mount sensors in the firebird's in 87 or 88 (i forget) and 90 in the camaro, it has been 4000 pulse sensor ever since.
great discussion, but why are there 2 very different plugs. One has the 2 "hooks" on the out side, an the other is 1 single hook in the middle.
shawn
shawn
The single hook plug is the one for the 2000 pulse.
The two hooks were the one for the 4000 pulse.
The 4000 was only used with a '7730 ECM
TMZIrocZ350
Oct 7, 2015 12:09 PM
HoosierinWA
Oct 7, 2015 10:15 AM
