4th gen rear strength?
Old Dec 17, 2005 | 09:16 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
how much power do u think a beefed 4th gen rear could handle. by beefed i mean and eaton posi with 30+ spline axles and 3.73 gears. im planing on putting in a 350 with about 400-450 hp and possibly a 100 shot of nitrous. will the rear hold up to this?
Old Dec 17, 2005 | 09:52 PM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
i would say so but, a few will disagree i'm sure.
Old Dec 17, 2005 | 11:06 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
it will hold until the first pass with slicks typically. i've blown them up before on built up LT1s on the street but sitting on a slick
Old Dec 17, 2005 | 11:35 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
There's really no way to know for sure. Some people have 10-bolts running 10 second ET's over and over, and others have blown up 10-bolts running 13's.
You're on the right track with a better posi unit and larger axles. Have you considered a rear end girdle/cover, too?
Old Dec 18, 2005 | 07:31 AM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
supoosably the girdle/cover can make a world of difference . Summit offers a nice heavy duty looking rear cover for 130 should eliminate a lot of flex.
If it makes any difference my neighbor races 1 behind his scca sorta street car with 400-450 hp running 10 in slicks and has had no problems for the past few years/races with a locking rear diff.
Old Dec 19, 2005 | 01:02 PM
MaNiAk86's Avatar
Car: 1983 trans am
thanx for all the help guys. i am gonna be doing mostly drag racing so is eaton my best option or are there better alternatives for my aplication? If anyone is selling a 4TH GEN REAR im interested./
Old Dec 19, 2005 | 01:31 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
3rd & 4th Gen 10-bolt rears are the same thing. You may think you are strengthening it, but you will get the same results if you abuse it.
Old Dec 20, 2005 | 05:43 PM
MaNiAk86's Avatar
Car: 1983 trans am
i thought that the 4th gen rear was 7 5/8 and the 3rd gen rear was 7 1/2. am i wrong?
Old Dec 20, 2005 | 07:35 PM
DJP87Z28's Avatar
GM change the Dia of the ring gear at some point during the 3rd Gen run. But it was the same or No difference to the so called strength of the 10-Bolt rear.
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
