RTV only on tranny pan
Old Jan 6, 2006 | 04:00 PM
llvll4l2c91350's Avatar
anyone used RTV only on a tranny pan? did it work?
Old Jan 6, 2006 | 04:04 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
According to GM, there are some pans you can use RTV with and some you shouldn't. The difference is in the ridges along the sealing surface. I don't rememberwhich is which.
Old Jan 6, 2006 | 07:28 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
I've always heard that you can't use it on any automatic. Somthing about the trans fluid dissolving it and running it through the system.
Old Jan 6, 2006 | 07:53 PM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Transmission: Pete K 700R4
Axle/Gears: 3:55
If you use rtv and accidently block the small servo dump passage, you will quickly burn up the trans.
Old Jan 6, 2006 | 08:34 PM
makes sense. RTV can get anywhere inside. thanks.
Old Jan 6, 2006 | 09:10 PM
firebird45331's Avatar
Car: 86 Firebird, 2002 Monte Carlo, 91 v
chryslers come from the factory and use nothing but rtv. I have yet to see a gm come from the factory with rtv.
Old Jan 7, 2006 | 09:16 AM
Floor guy's Avatar
Car: 89 Firebird
Engine: 406 CI
Axle/Gears: 3:55
GM will not use it on the pan rail because of the servo dump hole. It is only 1/8 of an inch away from the gasket. The last trans I did was killed by rtv in this hole. It only had 4k miles on it. Owner took it back to the trans builder for a service and he reused the gasket and rtv'd it. He is closed up now(bankrupt) no recourse except to rebuild it. $2 tube of blue silicone cost him $1100.
Old Jan 8, 2006 | 01:42 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The factory service manual allows the use of RTV. I'd rather use a gasket though.
Old Jan 8, 2006 | 10:20 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Thats the 2nd time Ive seen RTV in a service manual as a replacment for a gasket. Over at the Truck board some people were saying thier trucks came with RTV on the valve covers from the factory and showed a service manual scan to back it up.
Either way use a gasket. Tt's much safer then RTV, besides the mounting surface must be super clean and dry for RTV to cure properly.
Old Jan 8, 2006 | 01:23 PM
that's my biggest bitch about chrysler products they tend to use a lot of o-ring gaskets and rtv.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
88CamZ
Oct 8, 2015 10:29 AM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
