t-56 problems
Old Jan 13, 2006 | 05:29 PM
ssean92's Avatar
Car: sold
t-56 problems
ok guys got the tranny in the car for the 2nd time. i bought a new master slave assembly. my problem is it will go in to gear at a stop but when im moving and try to shift it grinds. the tranny is supose to only have 3k on it and i would believe it so i dont think it is the syncros. the only other thing that i can think it is is maybe im not getting enough clutch travel?????? any help would be nice. thanks Sean
Old Jan 13, 2006 | 05:45 PM
85 roc it's Avatar
Car: 85 IROC
Engine: 385AFR head, Mini Ram Intake
Transmission: 6 Sp.
try bleeding it some more
Old Jan 13, 2006 | 06:01 PM
ssean92's Avatar
Car: sold
brand new unit from gm
Old Jan 13, 2006 | 06:12 PM
85 roc it's Avatar
Car: 85 IROC
Transmission: 6 Sp.
Mine was brand new also, I had to bleed it 3 times to finally get it to function properlly
Old Jan 14, 2006 | 11:14 AM
ssean92's Avatar
Car: sold
ok guys i did bleed it out and there wasnt any air in it. it is still doing it. if i dont get on it it shifts but if i get on it it grinds??????? starting to sound like syncros????? i am so lost . and one other question with the pedal pushed al the way in should the rod go all the way down to were it turns from copper color to silver color. hope that makes since. looking for something simple. and also it is making a funny noise if i push the cluch all the way in. everything is new so that cant be it. is there a special way the clutch fork to go on the piolet bearing?
Old Jan 14, 2006 | 01:07 PM
ssean92's Avatar
Car: sold
update, well here it is think the synros are toast. it grinds from 1st to 2nd on acceleration only then down shifting from 4th to 3rd 3rd to 2nd 2nd any ideas on how much this would cost to get fixed? or if you think that is what it is?
Old Jan 14, 2006 | 03:10 PM
ssean92's Avatar
Car: sold
anyone?
Old Jan 14, 2006 | 07:59 PM
ssean92's Avatar
Car: sold
ok will not having the reverse lock out hooked up cause any problems? or the skip shift?????
Old Jan 17, 2006 | 08:23 PM
grover85's Avatar
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
It sounds like syncros to me. Also how do you blead a lt1 slave? When I put my t56 I didnt notice any bleeder screw.
Old Jan 18, 2006 | 06:57 AM
ssean92's Avatar
Car: sold
there isnt any bleed screw. you have to take it out, put the master cylinder in a vise and hold the slave cylinder at a 45 degeree angle, with the cap off pump the slave till you dont see any air bubbles, then pump the actuator that conects to the pedal till you cant move it any move, then repeat the slave cylinder steps. took me about an hour or so to get it all out. and yes it did help.
Old Jan 29, 2006 | 05:21 PM
ssean92's Avatar
Car: sold
well guys i took it out and took it to the tranny guy and the syncros were trashed, got them replaced and it shifts great now. i am so glad i did this mod. if you are looking for a tranny i would recomend this mod it isnt that hard and well worth it.
pjsparts
Oct 29, 2025 06:39 PM
tonys91rs
Oct 10, 2015 03:31 PM
88rscamar0
Sep 23, 2015 09:08 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
