T56 pedal install / switch question
Old Feb 5, 2006 | 03:49 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
I'm all over getting the hole drilled and the pedals mounted.
What I'm trying to figure out is what's going on with the switches. I've been searching for hours and haven't found my answers or I'm really confused.
I got pedals from a 4th gen. They came with 2 switches. One on the brake and one on the clutch.
My only brake pedal has 2 switches.
What switches are what and what get wired to what. I know I need the neutral saftey switch, I'd like to keep my cruise control.
I believe that switch #1 is for the cruise so i guess I could move this to the 4th gen pedals. Where does it need to be mounted? should I remove sw #3 and put this there?
What is switch #2 for? would this go in place of SW#4 on the 4th gen pedals?
So if I had to guess I'd say I'm missing the clutch saftey switch. Would this go in hole #1?
Thanks for any help that you provide.
Attached Thumbnails T56 pedal install / switch question-img_2059-large-.jpg
Old Feb 5, 2006 | 03:50 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
4th gen pedals
Attached Thumbnails T56 pedal install / switch question-img_2078-large-medium-.jpg
Old Feb 5, 2006 | 11:03 PM
ssean92's Avatar
Car: sold
u must have gotten another tranny i quess josh. thats cool. i used the third gen it was easier. im not sure on the stuff you got there. good lick though
Old Feb 6, 2006 | 07:12 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
yup. A couple of weeks after I sold you the one I had, the wife knew I was bummed about not putting in a 6 speed and bought another one for me.
Old Feb 6, 2006 | 07:47 AM
TKOPerformance's Avatar
Car: '86 Camaro, '02 WRX, '87 K5, '67
Engine: 350 TPI, 2.0turbo, 383 in the works, 289-4BBL, 232, A-head 4-cylinder
Transmission: T56, 5-speed, 700R4, C4, T176, semi-auto 2-speed
Axle/Gears: 3.73, 3.90, 4.88, 3.55, 3.54, 7.00
I used the thirdgen pedals too, and found it very easy. If you can just swap switches from the thirdgen brake pedal to the 4th gen pedal I'd just do that.
BTW, that's a good woman you've got yourself there!
Old Feb 6, 2006 | 07:48 AM
ssean92's Avatar
Car: sold
that is cool, good luck, hope you have beter luck then i did
Old Feb 6, 2006 | 09:01 AM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
On your old pedal, the switch with the vacuum port is for the cruise control, the other is for the stoplights. Hole #1 & the one to the left of it on the 4th gen pedals is for the 4th gen clutch saftey switch GM part# 14094368 & pigtail# 12102690. You can get them new from GM or scrouge in the salvage yards for them.
Old Feb 6, 2006 | 07:18 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
what is the pigtail????
Old Feb 13, 2006 | 08:02 AM
Br1dgeman's Avatar
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
Pigtail = the connector that goes into the aforemetioned switch with about 12" of wire extending out of the connector so you can splice into your wiring harness.
Old Feb 13, 2006 | 09:35 AM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
does anyone know how to wire the 4th gen stop light switch to the third gen wiring? The old third gen switch doesn't fit into the 4th gen switch mount. The third gen has 4 wires but the 4th gen only has 2.
Old Feb 13, 2006 | 01:25 PM
Ricktpi's Avatar
The 3rd Gen switch will fit if you use the 4th Gen switch retainer, GM part# 10200424.
Old Apr 14, 2006 | 11:55 AM
n8sz28's Avatar
Car: 85 camaro z28
Transmission: T56 6 speed
Axle/Gears: 3.27 borg warner 9 bolt
switch#3 from the 4th gen pedals above?
so what is switch #3 for on the 4th gen pedals. i have that on my 4th gen pedals too, but i don't have the switch i have the starter safety switch on my 4th gen pedals already hooked up is it necessary to have whatever gets hooked up into the switch #3?
1992 Trans Am
May 10, 2023 07:19 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
