rear end?
Car: 89 gta ws6, Dodge Turbo Diesel, H-D
Engine: 383 4-bolt #638 block
Transmission: 700r4, corvette servo, 2200 stall
Axle/Gears: 3.27 9 bolt b-w, pbr discs
rear end?
Does anyone know what rear end came in the 89GTAs with the 5.7L tpi? I thought all this time I had a 3.73 and now I just don't know. I looked on the axel to the left of diff (pass) side and it's cleaned to the metal and there is no stamped marking as Haynes says there should be. I did find a stamp on the bottom of diff that is G16e8 whatever that means. It is a posi, that much I do know!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The 89 GTA with a 5.7L TPI will have a Borg Warner 9 bolt diff. It will have 3.27 gears and a posi.
For more info on the 9 bolt, www.diffsolutions.com
rear end
I forgot to say it was a 10 bolt so what does that tell me?
thanks for the reply.
Re: rear end
9 bolt
I let my sons count it and well some of you know what I mean, 15 yrs old. So I went out and counted nine bolts so what do I have 2:77 or the 3:27? Is there a way to check for sure by using Vin code? your right it s a BW
9 bolt
Re: 9 bolt
GH3 = 2:77 BW rear axle ratio
GW6= 3:27 BW rear axle ratio
G80= Limited slip rear
Note: The Vin will only indicate the original engine installed at the factory.
reart end
thanks DJP I checked the RPO And I have the GW6 3.27 gear and the G-80 posi. Once you told me where to look it was pretty simple but I won't be arrested for removing the do not remove tag I hope.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
